Author Topic: front clip interchangeability  (Read 13639 times)
Offline serca
  • New Users
« on: February 22, 2003, 08:48:00 pm »
Have a 75 crew cab, will a full 83 clip and rad support bolt onto the cab ????
Offline 73K20
Re: front clip interchangeability
« Reply #1 on: February 23, 2003, 06:19:00 pm »
Yep it will work.  Read some of the other body swapping threads for info and problem areas.
1973 K20 - 350/350/205
Offline smokin77
« Reply #2 on: February 24, 2003, 04:53:00 pm »
Will a 73-80 front clip fit on a 86 cab?? I would assume so because it works the other way.
Clip
« Reply #3 on: February 24, 2003, 10:43:00 pm »
Yep it will fit just the wiper transmision problem.
Offline 73SUPERSPORT
Re: Clip
« Reply #4 on: April 02, 2003, 08:08:00 am »
Hey guys! New member here, I just picked up a 73 C-10, and im interested in this as well..I would like to do a whole 87 or 88 conversion but not sure how. How do you do a search? Thanks for any help you guys can give, and I look forward to restoring this truck to top shape.:eek
JAY!
Front clip
« Reply #5 on: April 03, 2003, 06:00:00 am »
Not sure what you mean by a search?
Re: Front clip
« Reply #6 on: April 03, 2003, 06:38:00 pm »
I am sorry, im use to posting things over at the Impala site. What all parts would be needed to do this swap? And could someone give me a ball park price for everything? Here is what I would like to do,
80's model fenders
tail gate
and 4 head light front end.
Please forgive me if I seem off, im new to the older truck stuff, but im learning:rollin  . Here some pics of my other ride.www.sounddomain.com/id/jaysimpala
Edited by: 73SUPERSPORT at: 4/3/03 7:39:45 pm
Clip
« Reply #7 on: April 03, 2003, 09:23:00 pm »
Prices vary depends on where your from and who you know. if it were me I would look for a whole truck. I have sold complete front clips for $75 to $350 depending on condition etc.. Not sure what year but they changed the position of the tail gate hinge latch assembly, the fold out braces that keep the gate from opening to far got shorter on the newer trucks. As afr as the frontend you need every thing from the doors forward, the windsheild wiper transmision assembly, the hood latch release handle/cable, and the wiring harness. As far as the hinges go you will need to cut pockets into your cowl to match those of the newer truck, the hinges are mounted to the cab from 81 up, just the springs mount to the fenders. You will need to drill some holes for the cowl filler panel in the cowl just below the rubber gasket, and some self tappers will srew the plastic screen down and it bolts to that and the hinge bracket in the front. The wiper transmision needs to have two of the three holes in each side moved about half a hole. And you will have to do some minor improvising to get the glass juice onto the wiper arms. The fuse box has a bolt ( 7/16 I think ) In the midle of it under the hood. Unbolt that and the harnes unplugs, the newer one will plug in but you might need to move some of the pin positions. I think that just about covers it.
Re: Clip
« Reply #8 on: April 04, 2003, 07:16:00 am »
Thanks for your help! Man that is a lot of work. After looking at the truck again there is really not that much of a difference. I think I will just focus on restoring her, as is. I will keep you all posted on progress. Thanks again!:hat
Offline RSBAD454
Re: Clip
« Reply #9 on: April 04, 2003, 01:32:00 pm »
im swapping my 81 front for a 89-91 suburban front end.....there are some slight changes when swapping between years, just minor.
Toys are my game
http://
Front clip
« Reply #10 on: April 06, 2003, 10:02:00 am »
Puting the older nose on the newer cab is alot less work. Going from 81 to 89-91 is just about a direct bolt on.
Offline RSBAD454
Re: Front clip
« Reply #11 on: April 07, 2003, 11:46:00 am »
yes going older is a little more involved but not too bad...mainly due to fenders and hood cowel.........but you need the whole front clip for either mod.
Toys are my game
http://
Front Clip
« Reply #12 on: April 08, 2003, 06:20:00 am »
How do you figure going older is more involved? Going older dose not require any cutting, welding, or fabrication of hood hinge pockets, to me that sounds like a lot less work. I have swaped 81 and up noses onto older trucks at least half a dozen times, and swaped a 76 nose onto an 85 last summer and it was alot easier going to the older nose.
Offline RSBAD454
Re: Front Clip
« Reply #13 on: April 08, 2003, 10:06:00 am »
i have done both myself............they are both easy to me, but you are right for the hood hinges i forgot..........:smokin
Toys are my game
http://
