Author Topic: 1977 c10 stepside shortbed  (Read 6926 times)
Offline ajones33
« on: April 11, 2015, 08:38:27 am »
i jus bought a 1977 c10 stepside with the inline 6 4.1l and three on the tree. I am trying to find out where I can buy parts for the three on the tree. It will not shift at all, something is broke inside column. Any help will be greatly appreciated! Thanks
Re: 1977 c10 stepside shortbed
« Reply #1 on: April 11, 2015, 12:05:43 pm »
Welcome from NW Indiana since this is your first post.  First of all there are no aftermarket rebuild kits for these columns unfortunately.  You may have to convert it to a floor shifter or if you are lucky enough to find a used one in good enough shape from a pick and pull.  I searched 7 years for a good column for my 86 before I found one.  84-87's were almost non existent.  If you can take some pictures of under the hood with the linkages I may be able to help.  Sometimes you can straighten it out if it is in between gears of sorts.  I also will have some good used parts from columns if you can identify what you need.
« Reply #2 on: April 11, 2015, 11:51:12 pm »
welcome from maryland
Offline jeremy.w.eason
« Reply #3 on: April 12, 2015, 12:37:11 am »
Welcome from Houston texas
Offline mjmhomes
« Reply #4 on: April 12, 2015, 01:42:35 pm »
Has the same set up, put it on the floor. After about three months canned it and put in a auto turbo 350 trans, runs like a top...
Offline ajones33
« Reply #5 on: April 12, 2015, 03:36:08 pm »
Zeig85 thanks I'll take some pics, mine is in the column somewhere, I'll post some pics soon everyone and thanks for all the replys!
Offline ajones33
« Reply #6 on: April 12, 2015, 06:16:29 pm »
Oh yea git's I live in Georgia
Offline roundhouse
« Reply #7 on: April 13, 2015, 05:33:01 am »
You'll have to remove the column and dis assemble
It
If something is broken you'll see it and get it welded back together
