1977 c10 stepside shortbed
Topic: 1977 c10 stepside shortbed (Read 6931 times)
ajones33
April 11, 2015, 08:38:27 am »
i jus bought a 1977 c10 stepside with the inline 6 4.1l and three on the tree. I am trying to find out where I can buy parts for the three on the tree. It will not shift at all, something is broke inside column. Any help will be greatly appreciated! Thanks
zieg85
Re: 1977 c10 stepside shortbed
April 11, 2015, 12:05:43 pm »
Welcome from NW Indiana since this is your first post. First of all there are no aftermarket rebuild kits for these columns unfortunately. You may have to convert it to a floor shifter or if you are lucky enough to find a used one in good enough shape from a pick and pull. I searched 7 years for a good column for my 86 before I found one. 84-87's were almost non existent. If you can take some pictures of under the hood with the linkages I may be able to help. Sometimes you can straighten it out if it is in between gears of sorts. I also will have some good used parts from columns if you can identify what you need.
April 11, 2015, 11:51:12 pm »
welcome from maryland
jeremy.w.eason
April 12, 2015, 12:37:11 am »
Welcome from Houston texas
mjmhomes
April 12, 2015, 01:42:35 pm »
Has the same set up, put it on the floor. After about three months canned it and put in a auto turbo 350 trans, runs like a top...
ajones33
April 12, 2015, 03:36:08 pm »
Zeig85 thanks I'll take some pics, mine is in the column somewhere, I'll post some pics soon everyone and thanks for all the replys!
ajones33
April 12, 2015, 06:16:29 pm »
Oh yea git's I live in Georgia
roundhouse
April 13, 2015, 05:33:01 am »
You'll have to remove the column and dis assemble
It
If something is broken you'll see it and get it welded back together
