Electrical
Distributor Terminals
Topic: Distributor Terminals (Read 13666 times)
IdahoMan
April 20, 2015, 05:45:14 pm »
Quick question..
On my Distributor's left(driver's) side there are labels and terminals. Like this:
\______________/
|"C-" GND "B+"|
| TACH BATT |
|____________|
(Also: See PIC)
It's terribly difficult to access or even see what's there, but it looks like five terminals and five wires: The three inner wires appear smaller and are red, green and black. The two outer a larger and both are red.
Can someone explain to me, or just link to, some info on what each of there are for and where they run to?
Thanks.
Sincerely,
IM
enaberif
Re: Distributor Terminals
April 20, 2015, 06:11:18 pm »
The main 3 are fed from the base of the distributor.
The other two provide power Bat+ and Tach.
April 20, 2015, 07:40:30 pm »
See image
IdahoMan
April 21, 2015, 12:34:15 am »
Thank you Vile.
Let me see if I understand this...
C- Terminal:
Ground Terminal:
To the vehicle body
B+ Terminal:
Battery Terminal:
To ignition Switch (so it must go through the firewall somewhere yes? To bulkhead or straight-through?)
Tach Terminal:
To a Tachometer. (I don't have one, but there is a wire running from the terminal to.. somewhere.)
IM
78BIG-TEN
April 21, 2015, 09:06:52 am »
The C-,gnd,bat terminals connect to the 3 wire connector from the module inside the dist.
The Bat+ is a switched ignition ffed to power up the coil.The tack is if you are running a tach otherwise not used
enaberif
April 21, 2015, 09:49:28 am »
Bat+ will be usually connected 1 of 2 days. Through the firewall to the fuseblock or to the bulkhead.
On older trucks there were points converted to HEI people generally ran a new wire through the firewall because points use a resistance wire which causes grief for hei.
For the tach wire well some trucks came pre-wired for them but others people added this and install their own tach.
IdahoMan
April 21, 2015, 02:02:35 pm »
78BIG-TEN, ena,
I'm afraid there is no "Bat+" on the Distributor.
There is:
"C-"
"GND"
"B+"
"TACH"
"BATT"
enaberif
April 21, 2015, 03:47:01 pm »
Quote from: IdahoMan on April 21, 2015, 02:02:35 pm
78BIG-TEN, ena,
There is:
"C-"
"GND"
"B+"
"TACH"
"BATT"
BATT .. BAT + .. same thing.. requires 12v lol.
78BIG-TEN
April 22, 2015, 05:44:50 pm »
Batt=Bat + in other words switched ignition power.Use a pretty heavy gauge wire here.
I use minimum size of 12 Gauge.If not using a tach then don't connect anything
timthescarrd
April 22, 2015, 06:12:18 pm »
Here you can see where the three back ones go into a module on the base of the distributor
As others have said, the TACH is to feed signal to a tachometer BATT is just a 12V source that has power only in ignition ON and START
IdahoMan
April 23, 2015, 02:52:26 am »
Major thanks.
Electrical
