Author Topic: JB5 or JD5 Brakes???  (Read 20385 times)
Offline SpartanTravis
« on: April 21, 2015, 08:26:39 am »
I have an 84 K10 I'm pretty sure I have a vacuum brake booster.
I'm trying to find out if my brake booster is a JD5 or a JB5. If anyone knows, please help me out. I have none of the identification stickers in the door jam, glove box, etc.
Here is my vin in case it help.
2GCEK14H1E1141337
Thanks,
Travis
Offline enaberif
Re: JB5 or JD5 Brakes???
« Reply #2 on: April 21, 2015, 10:16:26 am »
Thanks enaberif. So if I have a JB5 then I have to have the rotors and calipers to match correct?
Thanks,
Travis
Offline enaberif
« Reply #3 on: April 21, 2015, 10:49:27 am »
Not necessarily but its best to keep the system the way it was.
« Reply #4 on: April 22, 2015, 03:20:12 am »
if i had to guess i would think JB3. JB3 is for gvw of 4600lbs, while JB5 is for 6400lbs. the highest a ½ ton truck went to was 6200 and that was on the "BIG TEN".
« Reply #5 on: April 22, 2015, 05:22:09 am »
So if I was going to upgrade the system to a JB5, what all would I need to change? ie. Brake booster, master cylinder, calipers, rotors, drums, lines?
Thanks,
Travis
« Reply #6 on: April 22, 2015, 05:45:14 am »
let me ask you this, why? and what parts do you have now?
« Reply #7 on: April 22, 2015, 06:50:59 am »
Well I already have the rotors, drums, pads, and shoes I got from a buddy for next to nothing. So if I all I need is a brake booster and a master cylinder then I'll fork out for them.
Thanks,
Travis
« Reply #8 on: April 22, 2015, 08:58:43 am »
curious but are  they 6 lug or 8?
« Reply #9 on: April 22, 2015, 09:01:52 am »
i dont think the brake upgrade would be worth it only for 1800 lb difference.
« Last Edit: April 22, 2015, 09:14:34 am by Irish_Alley »
« Reply #10 on: April 22, 2015, 09:03:32 am »
They're 6 lug.
Thanks,
Travis
« Reply #11 on: April 22, 2015, 09:14:41 am »
will add this, i think the jb3, jb5 and jb6 use the same booster/cylinder.
to be clear youre talking about the new parts being 6 lug or the old or both?
« Reply #12 on: April 22, 2015, 10:05:00 am »
All the new parts are 6 lug.
Thanks,
Travis
« Reply #13 on: April 22, 2015, 10:28:43 am »
how do you know what type of brakes the new parts are? what the gvw of the new brakes? have you compared them to yours? (ie rotor size)
« Reply #14 on: April 22, 2015, 10:54:21 am »
He still had all the receipts for everything. I just looked them up. Everything is for a JB5. The brakes are 1 1/4 inch.
Thanks,
Travis
