Brakes and Braking Systems
JB5 or JD5 Brakes???
Topic: JB5 or JD5 Brakes??? (Read 20386 times)
SpartanTravis
April 21, 2015, 08:26:39 am »
I have an 84 K10 I'm pretty sure I have a vacuum brake booster.
I'm trying to find out if my brake booster is a JD5 or a JB5. If anyone knows, please help me out. I have none of the identification stickers in the door jam, glove box, etc.
Here is my vin in case it help.
2GCEK14H1E1141337
Thanks,
Travis
enaberif
Re: JB5 or JD5 Brakes???
April 21, 2015, 08:35:49 am »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=28592.0
SpartanTravis
April 21, 2015, 10:16:26 am »
Thanks enaberif. So if I have a JB5 then I have to have the rotors and calipers to match correct?
Thanks,
Travis
enaberif
April 21, 2015, 10:49:27 am »
Not necessarily but its best to keep the system the way it was.
April 22, 2015, 03:20:12 am »
if i had to guess i would think JB3. JB3 is for gvw of 4600lbs, while JB5 is for 6400lbs. the highest a ½ ton truck went to was 6200 and that was on the "BIG TEN".
SpartanTravis
April 22, 2015, 05:22:09 am »
So if I was going to upgrade the system to a JB5, what all would I need to change? ie. Brake booster, master cylinder, calipers, rotors, drums, lines?
Thanks,
Travis
April 22, 2015, 05:45:14 am »
let me ask you this, why? and what parts do you have now?
SpartanTravis
April 22, 2015, 06:50:59 am »
Well I already have the rotors, drums, pads, and shoes I got from a buddy for next to nothing. So if I all I need is a brake booster and a master cylinder then I'll fork out for them.
Thanks,
Travis
April 22, 2015, 08:58:43 am »
curious but are they 6 lug or 8?
April 22, 2015, 09:01:52 am »
i dont think the brake upgrade would be worth it only for 1800 lb difference.
Last Edit: April 22, 2015, 09:14:34 am by Irish_Alley
SpartanTravis
April 22, 2015, 09:03:32 am »
They're 6 lug.
Thanks,
Travis
April 22, 2015, 09:14:41 am »
will add this, i think the jb3, jb5 and jb6 use the same booster/cylinder.
to be clear youre talking about the new parts being 6 lug or the old or both?
SpartanTravis
April 22, 2015, 10:05:00 am »
All the new parts are 6 lug.
Thanks,
Travis
April 22, 2015, 10:28:43 am »
how do you know what type of brakes the new parts are? what the gvw of the new brakes? have you compared them to yours? (ie rotor size)
SpartanTravis
April 22, 2015, 10:54:21 am »
He still had all the receipts for everything. I just looked them up. Everything is for a JB5. The brakes are 1 1/4 inch.
Thanks,
Travis
