Author Topic: Roll on bed liner Herculiner  (Read 4859 times)
Offline 2butterbeans
« on: May 03, 2015, 11:43:14 pm »
Have any you guys tried Herculiner? What did you think of it?
Offline roundhouse
Re: Roll on bed liner Herculiner
« Reply #1 on: May 04, 2015, 07:10:17 am »
Works ok
I wouldn't use it on a truckbed
It's too cheap to get one sprayed in
I used it inside my 73 Bronco
Since all the truckbed places will spray a 8 foot bed for $99 but wanted $350 to do the inside in my bronco witch is waay smaller than a truckbed
Offline kalbert
« Reply #2 on: May 04, 2015, 11:19:35 pm »
I've used it on small things. Stair treads, trailer tongues, floor board on a forklift, inside a small fishing boat, stuff like that. I wouldn't use it on a whole bed. Too hard to make an even coat over a large area. The amount you'd need to make a coating half as thick as a spray on would cost almost the same, and it'd be blotchy and uneven. Worked very well on the little stuff though. Non slip and with good prep held up well and did not peel. Same goes for other DIY bed coatings.
« Last Edit: May 04, 2015, 11:21:37 pm by kalbert »
Offline roundhouse
« Reply #3 on: May 05, 2015, 10:12:39 am »
Makes the best glue in the world
They should make it without the clumps and in a squeeze tube
« Reply #4 on: June 04, 2015, 08:16:11 pm »
Its sucks!
