Author Topic: AC blower motor blowing fuse  (Read 4344 times)
Offline LosT_HaVoc
  • John Deere trained & certified service tech
« on: May 07, 2015, 04:10:08 pm »
Right now, I'm stuck in my college dorm, 300 miles away from my truck, but any ideas are helpful. I've replaced the fan speed switch and the resistor pack for the blower motor on my '87. Even after all that, it still blows the fuse when I turn on the fan. What could be wrong with it?
Proud owner of 1987 C10 & 1973 C65 Custom Deluxe
Just because I work on tractors doesn't mean I don't know anything about trucks.
Re: AC blower motor blowing fuse
« Reply #1 on: May 07, 2015, 04:21:50 pm »
What happens if you simply unplug the power wire from the blower motor?  Does it still blow the fuse?
Offline LosT_HaVoc
« Reply #2 on: May 07, 2015, 04:37:39 pm »
Haven't tried that yet. But I'll try it. Thanks
« Reply #3 on: May 09, 2015, 07:47:30 am »
can you even spin the motor by hand? voltage and amps to a motor depend on the resistance, so if a motor is hard to turn then the amps will rise or you have a short
« Reply #4 on: May 09, 2015, 08:42:42 am »
This is where you should have started prior to replacing any parts. By disconnecting the load in the circuit you can easily determine if that component is causing the high current draw. Do this and bring a test light or meter to verify the integrity of the circuit.
