Author Topic: 1978 k20 no power to starter  (Read 5285 times)
Offline hardin.chris123
« on: May 27, 2015, 08:37:34 am »
I was putting a new starter on my truck and I accidentally pinched the ignition wire in between the starter and block and I,didn't know at the time and tried to start the truck and some wires on firewall started smoking. I put some New wires in but starter won't get no power I put test light on ignition wire and no power. At all and fuse isn't blowed cam anyone help
Offline enaberif
Re: 1978 k20 no power to starter
« Reply #1 on: May 27, 2015, 08:49:25 am »
Probably popped a couple of the fusible links. Replace those and should be good.
« Reply #2 on: May 27, 2015, 09:02:01 am »
We're would those be located
Offline enaberif
« Reply #3 on: May 27, 2015, 11:06:58 am »
Either up neither the junction block or at the starter. They are fat little connectors located right near the connection points.
« Reply #4 on: May 27, 2015, 06:46:09 pm »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=11972.msg45217#msg45217
disconnect the negative battery cable when you do this and ensure nothing is improperly routed before you reconnect. Check at the starter solenoid and junction block on the firewall.
« Reply #5 on: July 08, 2015, 10:47:23 pm »
Sorry it's been awhile but when i pinched the wire between the starter and the block when I tried to start it the juction block started smoking I replace the block and I had no fuseable links they had been cut off before do you have any idea what else could be wrong with it I had to wire up a push button start on it for now but would like to have key switch working again
Sent from my VS985 4G using Tapatalk
