Author Topic: Blackout Wiring  (Read 4921 times)
Offline IdahoMan
Blackout Wiring
« on: June 07, 2015, 02:16:35 pm »
Mine was never a military vehicle, but I'd like to install a toggle switch to shut down all lighting except for the variable dash lighting (and maybe the horns).
I have not examine all the 81 Silverado wiring diagrams (the ones in the tech section are complete yes?) yet, but I'd like to ask if anyone here has done similar and/or has a good strategy for this.
Thanks.
IM
Offline roundhouse
Re: Blackout Wiring
« Reply #1 on: June 07, 2015, 04:44:33 pm »
A switch to kill he brake lights is all you need
Then just don't turn on the other lights
Some companies make a switch just for killing the brake lights that chirps when you hit the brakes to remind you that you dont t have brake lights
Offline IdahoMan
Re: Blackout Wiring
« Reply #2 on: July 03, 2015, 11:09:02 pm »
Would this be the brake-light-switch?
Offline LTZ C20
Re: Blackout Wiring
« Reply #3 on: July 05, 2015, 03:29:36 am »
Yep that's a brake switch.
LTZ Cheyenne C20
Offline IdahoMan
Re: Blackout Wiring
« Reply #4 on: July 15, 2015, 02:03:23 pm »
There are two slitches being pressed by thr brake pedal:
1. The one shown above. it has two plugs of wires goinh
g into it fron the top: white wire & orange wire on one ug, and a black wirr and green wire on the other.
2. There is a larger white "T" shaped switch to the right of the switch shown above. There is a plug going into its side with a lightblue & pnk/blck wires.
The wiring diagrams mention thr orange snd white being for the brake light yes?
Offline LTZ C20
Re: Blackout Wiring
« Reply #5 on: July 15, 2015, 02:12:41 pm »
White and orange are for brake lights. Black and green are torque converter lock up I think. Not sure about the other switch, probably cruise control I would guess. Check the wiring diagrams for your year.
LTZ Cheyenne C20
