Author Topic: Wiper Hi Speed Intermitten Operation  (Read 3936 times)
Offline kuhnzoo
« on: June 18, 2015, 07:34:19 pm »
85 K10, 305, 700R4. Wipers work on low setting, but stop (where ever they are) when placed on Hi setting. However, if I cycle the high beam switch the wipers will then work on the Hi settings. Strange, huh? Anyone have any ideas or similar experience?
These are standard off/lo/hi wipers - no delay feature.
Thanks!
Rob
1985 K10 350CID A/T
Re: Wiper Hi Speed Intermitten Operation
« Reply #1 on: June 19, 2015, 07:54:30 am »
im going to say poor contact in the switch itself. and when you cycle high beams it gives it enough contact to start it. this is a 100% guess and i cant even tell you how to test it
Offline kuhnzoo
« Reply #2 on: June 19, 2015, 08:21:46 am »
Yeah, I was leaning toward the switch as you mention. Could not see anything obvious on wiring schematic that looked like the hi speed wiper circuit was inter-related to the high beam circuit.
Only thing they seem to share is a common integration in stalk.
Thanks,
Rob
Sent from my MB520 using Tapatalk 2
1985 K10 350CID A/T
