Author Topic: No idle  (Read 3587 times)
Offline Nj1986k10
No idle
« on: June 21, 2015, 10:04:10 am »
My chevy k10 wont idle untill i rev it up for like 5 minutes and i have no clue why. Could it be because i took off the charcoal can and didnt plug the lines? Do i need to adjust choke or something? I really need help, thanks. Btw motor is a sbc350 with q jet, 10:1 compression heads cam etc.
Re: No idle
« Reply #1 on: June 21, 2015, 11:37:00 am »
if you didnt plug a line it should leave a vacuum leak then if the choke opens up it will be worse if not run at all. but yes plug all lines and see how it runs then
Offline Nj1986k10
Re: No idle
« Reply #2 on: July 02, 2015, 10:03:49 pm »
I fixed it, turned out that the throttle screw was set so it fully closed and gave it no gas at idle. Now i just gotta fix a blown head gasket
