Author Topic: how to drain the driver side gas tank of a 1986 chevrolet k10 5.7L 350 4x4.  (Read 5949 times)
Offline cal2200
I can't cypher the gas out because it won't let me and i can't find a drain plug. Does anyone know how to drain these gas tanks?
Offline bowmank10
Best thing I found to do is to torch a hole in the tank with an oxy-acetylene torch ........just kidding don't do that....
But seriously, you should be able to just siphon out of the filler neck
Sent from my XT1254 using Tapatalk
« Last Edit: June 22, 2015, 08:25:38 pm by bowmank10 »
Git R Dun.
Offline LTZ C20
Reach up thru the front area of the rear fender wheel well, loosen the clamp on the filler hose, remove the hose off the tank, syphon the fuel out directly at the tank, bypassing the filler hose completely. Your syphon hose is probably having issues making the bends in the filler hose to get into the tank.
LTZ Cheyenne C20
Offline cal2200
Thanks! That's what I did and it worked great ;D
Offline LTZ C20
Welcome.
LTZ Cheyenne C20
