Body, Glass & Paint
whats the diff
Topic: whats the diff (Read 10493 times)
gmc85
whats the diff
September 19, 2003, 11:50:00 pm »
i was wondering what the diference was between a 73 door and an 85 because i need a door for my 85 and have a 73 door but not sure if it would line up right.
gmc85
k
September 24, 2003, 08:36:00 pm »
does any one know if there is any cosmetic diferences
smokin77
Re: k
September 24, 2003, 10:22:00 pm »
As far as I know.......The outside is the same, on the inside 73-76 door shells have a smaller plastic panel than 77-87 doors. So on the inside the door shell is different.
gmc85
k
September 25, 2003, 08:10:00 pm »
ok thanks thats all i really needed to know
73K20
73 doors on an 85
September 26, 2003, 08:44:00 am »
As mentioned they are different on the inside and use different door panels. The exterior has the same body lines so it will match up. The 73 door has a different window and crank mechanism than the newer 85 door. These are not interchangeable. You will have to use the window that came in the 73.
1973 K20 - 350/350/205
gmc85
o
September 27, 2003, 11:03:00 am »
so i cant just use my windows or there cranks or any other of the inards?
smokin77
Re:difference
September 28, 2003, 10:12:00 pm »
Pretty much!
gmc85
k
September 29, 2003, 09:27:00 pm »
well that sucks
ITC
Re: k
September 30, 2003, 04:57:00 am »
Yeah the regs are different... Perhaps you could drill a few holes to get the older door to work??
blazer1961
Re: k
January 23, 2004, 10:41:00 pm »
lists the door panels as 73-76....77-87 don't know what the diff is but hope this helps.....................bob
Body, Glass & Paint
whats the diff
