Interior & Equipment
custom door panels
Topic: custom door panels (Read 11083 times)
FOOSE
custom door panels
June 25, 2015, 11:08:33 pm »
Hello guys,
I'm working on the interior of my truck now and I'm debating on customizing the factory ones or buy the ones from the store. are they still available and how well do they fit? will they fall off with the slam of the door cause I see some pictures that have screws all the way around so I'm wondering if they don't want to stay properly.
thanks
Re: custom door panels
June 27, 2015, 12:27:27 pm »
Pictures with Screws?
The Rod Doors panels are available but keep in mind that picture is what the owner did to them.
The don't fall off with the slam of the door, under the armrest portion is a metal plate that the pull bolts to...
FOOSE
June 29, 2015, 12:52:29 pm »
ok I meant like the corners, will they let loose cause they are only held on with Velcro, the picture I just add has screws to hold it into place, just wondering if that may be a problem with the Velcro letting loose and the panels start rattling.
June 29, 2015, 06:22:14 pm »
They are not held on with "velcro" as in what holds a shoe on. It is 3M Dual Lock fasteners. I recommend riveting the dual lock to the door panel and to the door to hold it on as if it gets a good contact it will pull the tape off the door.
This is the Dual Lock "velcro"
http://solutions.3m.com/wps/portal/3M/en_US/Adhesives/Tapes/Products/~/3M-Dual-Lock-Reclosable-Fastener-SJ3870?N=5927706+3294281433&rt=rud
FOOSE
June 29, 2015, 09:22:56 pm »
ok sounds like they are pretty solid, how long does it take to get them if I order from your store? do you know who made this door panel (pictured)? It looks like a roddoors panel but heavily modified. any forums or articles that shows how its made?
Thanks
June 30, 2015, 08:04:14 am »
What you posted is a Rod Door panel that was built for Mike Losh's Square Peg Blazer by Chuck Bench at Stitch Interiors (now called Automotive Professional Interiors LLC)
http://www.autoprointeriors.com/
You might can find pics on his OLD FB page here,
https://www.facebook.com/stitchrodtrim
Keep in mind these door panels come bare and it is about 3-4 weeks before they are shipped from the time the order is placed. (he has been faster, but that is the time he ask for)
FOOSE
June 30, 2015, 12:43:15 pm »
thank you, I found a few pictures and it gave me some ideas!
custom door panels
