73-87 Chevy & GMC Trucks
Water leaking into cab from hood hinge rubber gasket area of 1984 Silverado Step
Topic: Water leaking into cab from hood hinge rubber gasket area of 1984 Silverado Step (Read 4200 times)
Chuck Step-a-side
July 14, 2015, 08:59:46 am »
Has anybody have or had water leaking into the cab of 1984 Silverado Stepside from the cowl area where the rubber gasket is for the hood hinge? How can I stop the water from leaking there? Thanks, Chuck
Last Edit: July 14, 2015, 04:15:30 pm by Chuck Step-a-side
jaredts
Re: Water leaking into cab from hood hinge rubber gasket area
July 14, 2015, 03:46:47 pm »
Yes its a common problem. Remove the cowl panel and look for the seam sealer coated seam. Missing seam sealer and/or rust holes will cause water to leak into the cab.
Chuck Step-a-side
Re: Water leaking into cab from hood hinge rubber gasket area of 1984 Silverado Step
July 14, 2015, 04:27:05 pm »
Do you know if those rubber seals for the hinges available? Thank you, Chuck
jaredts
July 14, 2015, 04:28:57 pm »
It is available--I bought one not too long ago for my truck but forget where I got it. Try Chris on this site first--he can tell you where to get it if he doesn't carry it. It won't help your cab leak though.
Chuck Step-a-side
July 16, 2015, 07:59:30 am »
Thank you Jaredts.
