Author Topic: Need help  (Read 6081 times)
Offline shep07
Need help
« on: July 19, 2015, 11:10:36 pm »
Hi i have a 1976 chevy k20 im trying to plan out my stereo, dont know where to put my speakers there is no brackets for them.. Any ideas?
Offline Jae222
Re: Need help
« Reply #1 on: July 20, 2015, 07:59:42 am »
You should consider putting you speakers in the dash .. 3 inch speakers does a good job .. Many  as 4 speakers will fit up there , 2 on the sides , and 2 in the middle .. It does require Minor  metal fab to make them fit flush .. Good luck
Offline Mikeymike383
Re: Need help
« Reply #2 on: July 20, 2015, 08:31:36 am »
Yah putting some n dash. Kick panel speakers and the floor and maybe a speaker box behind seat
Sent from my SAMSUNG-SM-T337A using Tapatalk
383 stroke
Offline shep07
Re: Need help
« Reply #3 on: July 20, 2015, 10:06:16 am »
Will consider thanks guys
Re: Need help
« Reply #4 on: July 20, 2015, 11:05:02 am »
http://www.73-87.com/  had them available.  It has been a while since I've purchased them from him but here you go.
Offline timthescarrd
Re: Need help
« Reply #5 on: July 20, 2015, 11:36:20 am »
I found a truck in the junkyard that had factory brackets for 4x10 speakers in the corners behind the seats.  I was able to use a grinder to cut out the holes and make 6x9s fit there, they are a little muted by being behind the seat, but i put two 3.5" rounds in the dash and now the setup sounds good.
Offline harcorshe
Re: Need help
« Reply #6 on: July 20, 2015, 05:35:13 pm »
I have a 78 K20. It does not have holes in the dash for small speakers, instead there is a single (broken) 4x9 speaker in the middle. I used this space to house my amp.
When I got it, there were 4x9 speakers in the rear. I changed these to 6x9 using the excellent brackets from 73-86.com.
I also put 6 inch speakers in the door (the PO had already cut holes).
'78 K20
454
TH400
14 Bolt
205 Transfer Case
