Author Topic: Stopping the rust till time for professional bodywork?  (Read 6998 times)
Offline Rustbucket86
« on: July 24, 2015, 06:53:07 pm »
I have the usual bad rust around the bottom of my cab, and I was wondering what the best method of stopping it temporarily would be. Should I sand it down and spray some rust preventative primer over it or just cut it out completely? I do not have access to a wielder or sandblaster.
Re: Stopping the rust till time for professional bodywork?
« Reply #1 on: July 24, 2015, 07:55:26 pm »
Rust converter and then rusty metal primer then top coat. Harbor freight carries all of that stuff now too
« Reply #2 on: July 24, 2015, 08:04:38 pm »
Great! I love an excuse to go to Harbor Fright. Another question, the rust on the firewall has eaten completely through to the insulation. Should I worry about engine fumes leaking into the cab? What's my best option for this?
Offline philo_beddoe
  • 77 C-10
« Reply #3 on: July 25, 2015, 06:56:26 am »
Rust reformer by rustoleum.  For that hole, use maybe that metal tape. Or some thick padding type insulation if its not a hot area.
1 John 2:15-17
Jeremiah 17:7
Offline SugarCane
« Reply #4 on: July 26, 2015, 11:10:54 pm »
Rust reformer works well but is black. I recently discovered VHT Rust converter, and it is clear and only darkens the rust, similar to navel jelly.
Sent from my SM-N900V using Tapatalk
« Reply #5 on: August 02, 2015, 01:22:44 pm »
if you dont have exhaust leak you should be ok with the firewall BUT i would fix it before it gets really bad
Offline ccdually
« Reply #6 on: August 03, 2015, 11:36:54 am »
At the body/restoration shop I manage we use POR15 and have had great luck with it.
