Author Topic: 77chevy step side  (Read 5870 times)
Offline weatherfordjacey
77chevy step side
« on: August 04, 2015, 11:30:59 am »
What would my 350 sound like if she's only running on 7 cylinders it's the original motor an trans I know the Carb needs some choke adjustment an idle adjustment every time I step on the gas it starts to pop an crackel need help it's my daily driver
Sent from my LG-D415 using Tapatalk
Re: 77chevy step side
« Reply #1 on: August 04, 2015, 11:39:05 am »
Popping out the exhaust or back through the carburetor and air cleaner?  Is it worse if you rap the throttle quickly?  What do you mean by "crackel?"
« Reply #2 on: August 04, 2015, 12:24:59 pm »
if you wait till your engine is cold then start it up you can use a laser temperature gun and read each exhaust manifold port and see which port is colder than the others. if you dont have a temp gun you can use your fingers just be careful of moving parts. it will take the engine a little while to get up to too hot to touch but you will need less than 30 seconds to touch each one
« Reply #3 on: August 04, 2015, 12:40:34 pm »
Bd- I haven't really looked to see if it's coming from exhaust or Carb yet just started yesterday an the crackeling is just when it's about to shift the popping gets faster which makes it sound like a crackel an Irish_alley thanks for that I can get a hold of a temp gun
Offline travisr1988
« Reply #4 on: August 04, 2015, 04:23:53 pm »
Check plugs and wires? Maybe run a cleaner through the carb? Timing set where it should be?
1979 Chevrolet Silverado C20 rclb cammed 355/th400/4.10 - sold
1977 Chevrolet Custom Deluxe c10 rcsb stepside 355/th350/3.42
Vortec heads lunati cam edelbrock intake headers
« Reply #5 on: August 04, 2015, 04:27:18 pm »
Yea the timings good I just started her up after work one day when I hit the gas it was popping
Offline travisr1988
« Reply #6 on: August 05, 2015, 09:42:03 am »
Does it stumble too? Sputter?
« Reply #7 on: August 05, 2015, 03:44:21 pm »
Yea it kinda bogs down a little
Offline travisr1988
« Reply #8 on: August 05, 2015, 10:49:42 pm »
Clean your carb and check filter and make adjustments if needed. Usually a bog is a fuel issue, either not enough or too much. Also make sure your pump is within the pressure range for your carb. I talked to a guy who replaced 4 carbs because they wouldn't work right after he put in a 7-9 psi pump...all 4 carbs stated max pressure was 5-7 psi, but he was told by the parts store that no mechanical pump can exceed 6 psi, after the sold the higher pressure pump to him. Btw, too much pressure guarantees a rich condition and likely flooding.
« Reply #9 on: August 06, 2015, 03:56:17 pm »
Thanks man I'll check all this out an get back to you on how it went
