Author Topic: Ground strap bolt at firewall is stripped. Best way to secure this ground wire?  (Read 3628 times)
Offline hondaman
Long story short.  Truck wouldn't start, so I started looking at the ground points.  Found the loose connection at the firewall.
Problem is, the bolt is stripped and will never get a good ground.  Whats the best way to fix this?
[youtube]https://youtu.be/2z6YOWvBXUY[/youtube]
Can you get to the other size with a nut?  If not run a larger bolt through it?
Online bd
Make sure the cab sheetmetal is shiny, smear it with a little antioxidant, and use the next larger screw size if you can.  Don't over tighten it.
Offline enaberif
I put the ground strap from the engine cylinder head to the bracket for the brake booster lol.
