73-87 Chevy & GMC Trucks
I need help !!!
Topic: I need help !!! (Read 3369 times)
Mikeymike383
I need help !!!
August 22, 2015, 03:58:10 pm »
I have a 73 chevy c10 camper special. It had 2 gas tanks.. now only has the pass side tank.. I need help hooking it up so my gauge can read it.. my sending unit has 2 red wires coming from it
383 stroke
Chuck Step-a-side
Re: I need help !!!
August 26, 2015, 06:50:50 am »
Mike, it obvious that you have a dual tank and if it's a factory built then you should have left and right tank switch on the dash. If that is the case then you have a fuel switch valve on the frame somewhere. I would replace the fuel valve switch and the hose connection and that should restore the use of both tanks and fuel gauge.
1967KaiserM715
1985 GMC K1500 w/ 6.5 TD
Re: I need help !!!
August 26, 2015, 10:58:14 am »
Actually how I read you only have one tank, and your gas gauge reads half full when empty, so I would say a new sender, maybe new gauge to match said sender is the only solution. I don't think the wiring would allow to read just one tank.
Current Vehicles:1985 GMC K10(Daily) 1991 GMC K2500(Daily) 1975 Beetle(not running) 1985 Mercedes 300D(not running) 1952 M35 1967 M715(not running)
1986 Chevy K30(under repair)
I need help !!!
