Author Topic: I need help !!!  (Read 3366 times)
Offline Mikeymike383
I need help !!!
« on: August 22, 2015, 03:58:10 pm »
I have a 73 chevy c10 camper special.  It had 2 gas tanks.. now only has the pass side tank.. I need help hooking it up so my gauge can read it.. my sending unit has 2 red wires coming from it
383 stroke
Offline Chuck Step-a-side
Re: I need help !!!
« Reply #1 on: August 26, 2015, 06:50:50 am »
Mike, it obvious that you have a dual tank and if it's a factory built then you should have left and right tank switch on the dash. If that is the case then you have a fuel switch valve on the frame somewhere. I would replace the fuel valve switch and the hose connection and that should restore the use of both tanks and fuel gauge.
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: I need help !!!
« Reply #2 on: August 26, 2015, 10:58:14 am »
Actually how I read you only have one tank, and your gas gauge reads half full when empty, so I would say a new sender, maybe new gauge to match said sender is the only solution. I don't think the wiring would allow to read just one tank.
 1986 Chevy K30(under repair)
