Interior & Equipment
Steering Columns
Key stuck and locked in to run postion
Topic: Key stuck and locked in to run postion (Read 5982 times)
reed85
September 01, 2015, 06:59:09 pm »
My key is stuck in the ignition and its locked in the run to makr things worse the turn key ignition broke apart fixing to post a pic
Reed85C30
zieg85
Re: Key stuck and locked in to run postion
September 01, 2015, 07:06:27 pm »
Pull the B+ off the coil and then unhook the battery. Easiest fix is a replacement column. 1984-87 C/K and 88-91 R/V series is all the same.
September 01, 2015, 07:09:37 pm »
Changing the lock cylinder is simple and inexpensive. You need a few tools that you can either rent or purchase at any auto parts store or harbor freight. Look at the service manuals for reference.
reed85
September 02, 2015, 10:00:46 am »
Found out it was missing a few things so got another column for parts and getting a new key ignition thanks guys
Reed85C30
Steering Columns
