Author Topic: Looking for New Fuel Filler and Vent Hoses  (Read 4999 times)
Offline BBM3
« on: September 08, 2015, 02:30:26 pm »
1975 K10 Short Bed (16 gallon tanks).
The right hand tank on mine are cracked and hard as a rock.
Is there a fuel safe, less expensive option to replace the molded rubber filler and vent tubes other than those sold by on-line restoration parts places?
Re: Looking for New Fuel Filler and Vent Hoses
« Reply #1 on: September 08, 2015, 03:55:07 pm »
Have you researched Filler Neck Supply Company?
Offline BBM3
« Reply #2 on: September 08, 2015, 04:22:13 pm »
Thanks for the replay and link.
I need to replace the two rubber hoses / tubes between the metal filler neck and the tank.
Best price I have found for the pair is $40 plus shipping.
I could use a radiator hose for the filler and heater hose for the vent but I don't think those would be a good choice for fuel.
« Reply #3 on: September 08, 2015, 04:49:47 pm »
...I could use a radiator hose for the filler and heater hose for the vent but I don't think those would be a good choice for fuel.
Agreed.  Alcohol enriched fuels will cause rapid drying and breakdown of any rubber not manufactured to contain it.
Offline BBM3
« Reply #4 on: September 08, 2015, 05:52:19 pm »
Thanks for the conformation.
The fuel here in Colorado contains 10% ethanol.
I have replaced all of the other rubber sections of fuel line because they were rotted. I assume a combination of age and ethanol.
A previous owner must have replaced the LH filler and vent hoses as they are the only ones that look and feel new.
Offline 76LongBox
« Reply #5 on: September 10, 2015, 03:23:19 pm »
I tried a radiator hose once, and it worked for a while but eventually cracked and started leaking as I was filling up.  This was on NON-ethanol fuel even.  So I sprung for the $40 and ordered both the filler neck hose and the vent hose, and all has been well ever since.
« Last Edit: September 10, 2015, 07:18:32 pm by bd »
Offline BBM3
« Reply #6 on: September 10, 2015, 07:00:04 pm »
Thanks for the reply.
I ordered the fill and vent hoses today.
After all of the time I have spent repairing my dual tank fuel system I decided to just buy the final two correct parts and be done with it.
