Author Topic: Caprice wheels... uh oh  (Read 7658 times)
Offline a.graham52
« on: September 19, 2015, 08:29:09 pm »
So long story short, I spent good money on some nice wheels that came off a caprice and they don't fit my 77 big 10. Hubs are larger on the big 10 apparently.
What can I do to make these work? Or atleast opinions.
1. Have wheel hubs machined to fit
2. Spacers may do the trick, but hard to find hub centric that changes size.
3. Resell (don't want to if I can help it)
« Last Edit: September 20, 2015, 07:02:44 am by a.graham52 »
Offline frotosride
    • WFO CONCEPTS
Re: Caprice wheels... uh oh
« Reply #1 on: September 19, 2015, 08:55:48 pm »
If the lug pattern is  the same the center can certainly be machined. I almost did this for a set of early 90's k15 wheels bc I looked the way they looked mocked in place. B T I found the aluminum Mikey's for 120 on cl and got them instead. I've seen 2 people open the hub centers themselves and had no problem but tool control and heat input are critical.
Offline SkinnyG
  • Reducing resale value since 8-track days
« Reply #2 on: September 20, 2015, 12:17:48 am »
Some guys will stack a couple of hole saws on the hole saw arbor, so one saw references the existing hole, and the other (larger) one cuts the hole bigger.
This keeps you reasonably centered, but the wheels will no longer be "hub-centric" when you're done.  That may or may not be a problem.
The Crusty Chevy: 1977 Silverado, shortboxed & dropped, potato-potato.
Offline a.graham52
« Reply #3 on: September 20, 2015, 07:07:35 am »
Yeah I'd like to keep them hubcentric just to keep all possible strength. I still use the truck as a truck. Iv been woundering if the best thing to do is just have the wheels milled to a nice tight fit. I worry the baxk spacing isn't going to be 100% in my favor so this would atleast allow me to find hub centric spacers easily if need be
« Reply #4 on: September 20, 2015, 07:18:06 am »
What year Caprice did the rims come from?  Unless they are aftermarket all big bolt GM rims should fit our 5 on 5 C10.  Any pictures?
Offline a.graham52
« Reply #5 on: September 20, 2015, 07:34:59 am »
That's a screen shot of the original craigs ad. The pic I saw of the wheels on a car was just the front clip, it was a round car and not the square of the early 80.
« Reply #6 on: September 20, 2015, 08:04:52 am »
Those rims are for a FWD car with that offset
Offline a.graham52
« Reply #7 on: September 21, 2015, 11:51:45 am »
I'm curious what they fit. 5x5 bolt pattern with 1" back spacing. Not even enough back spacing for my saturn vue
« Last Edit: September 21, 2015, 12:22:43 pm by a.graham52 »
Offline Stewart G Griffin
« Reply #8 on: September 26, 2015, 08:39:21 am »
They look aftermarket anyways.
