Author Topic: Reproduction Bed Fitment- frustrated  (Read 5690 times)
Offline bowmank10
« on: October 04, 2015, 06:09:40 pm »
Finally got around to putting the bed together on my 1980 k10. I bought two repop bed sides, which don't fit worth a dang and when I went to see if my tailgate fits, it doesn't of course. It seems like the bed sides are to close together and the tailgate doesn't fit between the two by about 1/4". Any ideas?
Sent from my XT1254 using Tapatalk
Git R Dun.
Offline Don5
Re: Reproduction Bed Fitment- frustrated
« Reply #1 on: October 04, 2015, 06:32:22 pm »
Have you welded the back of the bed yet? If you have welded the rear of the bedsides, cut the weld and mount the tailgate. You don't weld the rear of the bedside until after the tailgate is mounted. This is what I have been told. This way you can get the gap right on both sides. Good luck  and I hope this helps.
Offline bowmank10
« Reply #2 on: October 04, 2015, 06:36:18 pm »
I have not welded yet....bed sides are just bolted.
Git R Dun.
Offline Don5
« Reply #3 on: October 04, 2015, 07:10:27 pm »
I would use a load lock or something like that to spread the bedsides apart until the gap is right. Then I would spot weld it and check for fitment. If you don't have a load lock use a 2x4 and a bottle jack or portapower .
Offline 87max
« Reply #4 on: October 13, 2015, 05:56:58 pm »
loosen up bolts to floor , mount gate, place shims on each side to preferred gap, weld the floor to sides retighten bolts.
88 R30 lb7 transplant in progress
04 E350 6.0 studded & tuned work van
98 Taurus beater
Offline bowmank10
« Reply #5 on: October 17, 2015, 09:51:49 pm »
Ended up doing exactly what 87max suggested and now it fits pretty dang good...thankyou
Git R Dun.
