1995 impala ss rear end on 85 stepside ?
Topic: 1995 impala ss rear end on 85 stepside ? (Read 6515 times)
85c10stepcustom
Showstopper
October 10, 2015, 12:14:57 pm »
Does anyone know if you a rear end out of a 1995 Impala with posi would swap out with the stock rear end out of my 1985 stepside ?
Re: 1995 impala ss rear end on 85 stepside ?
October 10, 2015, 06:56:32 pm »
It's a smaller unit and designed to work with coil springs. Why do you want to swap the rear end?
⌠ŻŻŻŻŻ' [☼===☼]
85c10stepcustom
Showstopper
October 11, 2015, 02:05:13 pm »
Disc brakes and posi !
October 11, 2015, 02:14:51 pm »
It is and 8.5 like the 81-87 1/2T trucks. I think (if memory serves me right) that they are slightly narrower.
October 11, 2015, 06:19:16 pm »
I'm pretty sure they were all highway geared too.
⌠ŻŻŻŻŻ' [☼===☼]
October 13, 2015, 09:40:30 pm »
Yes, 2.56 for non Impala SS and 3.08 for the SS.
30 spline axles and the SS had a limted slip factory.
Mtrhd329
November 13, 2015, 08:35:39 pm »
I swapped one into my 79. Cut off the perches and welded on new ones to flip the axle. Swapped in 3.73s a buddy had and a true trac and it runs great. Had to run. 2" spacer but if you want larger tires you could just get larger rims
