Author Topic: Copper goop to repair a PCB?  (Read 3433 times)
Offline jumpkickyergunt
« on: October 11, 2015, 04:37:00 pm »
Is there a pastey copper material or something that will fix a crack in my cluster PCB? It's right next to where the bulb inserts near the top of the fuel gauge. As of right now there is a voltage drop shown in the gas gauge whenever the lights are turned on or the turn signal clicks on. If I put a screwdriver across the cracked part everything appears to go back to normal.
Re: Copper goop to repair a PCB?
« Reply #1 on: October 11, 2015, 06:47:18 pm »
You can solder a repair with a jumper wire or use a printed circuit repair kit.
Offline enaberif
« Reply #2 on: October 11, 2015, 10:45:32 pm »
Could try one of those defroster line repair kits.
« Reply #3 on: October 13, 2015, 07:15:49 pm »
Just don't use one that has resistance
« Reply #4 on: October 14, 2015, 08:02:49 pm »
i know at my napa and autozone they stopped carrying the defroster repair kit
