Author Topic: radiator replacement choices  (Read 12885 times)
Offline p7387
« on: October 13, 2015, 04:33:46 pm »
87 short fleet 2wd
i will be getting around to replacing the radiator, will any brand be ok?
my local supplier had "APD" brand.
while i am at it i will be replacing the upper/lower hoses, heating hoses and thermostat
any other ideas?
thanks
Re: radiator replacement choices
« Reply #1 on: October 13, 2015, 04:43:36 pm »
Waterpump if you haven't done it in a while.  Need a radiator in my 84 as well...
Online bd
« Reply #2 on: October 13, 2015, 04:44:50 pm »
...and cap.
Offline p7387
« Reply #3 on: October 13, 2015, 05:04:34 pm »
any brand ok
"APD" ?
also the supplier said he had two choices
28.25" x 17"  (or 19")
i need to go measure
« Last Edit: October 13, 2015, 05:09:58 pm by p7387 »
Offline BBM3
« Reply #4 on: October 13, 2015, 06:26:10 pm »
I would ask myself these questions.....
Is you current radiator original?
Is it leaking? If so where?
How many cores in your current radiator vs. the new one?
Do you have air conditioning and or an automatic transmission?
How about having your current radiator rebuilt?
If you have your radiator re-cored you know it will fit and should last decades.
I replaced my original brass radiator with an aluminum / plastic one with fewer cores and it works fine
however I kept my original and will someday have it rebuilt.
Final thought...
Before you replace your radiator remove the thermostat, reinstall the neck without the thermostat and while running the engine  flush, flush, flush.
« Reply #5 on: October 13, 2015, 06:51:33 pm »
Rows, not cores. A 3 "Core" radiator means the core has 3 rows etc
Offline BBM3
« Reply #6 on: October 13, 2015, 08:36:41 pm »
Correct.
Thanks for the clarification.
Offline p7387
« Reply #7 on: October 14, 2015, 12:32:14 am »
the radiator appears to be original
the specific leak is where the upper heater hose inserts into the radiator
Offline p7387
« Reply #8 on: October 14, 2015, 01:48:38 pm »
1987 r10 2wd 305 motor auto
the part store is showing two options for the radiator, one listed at 17" and one at 19"
which is the correct option?
i measured the height of the original to be 19-20", (i think its the original rad)
thanks
Offline BBM3
« Reply #9 on: October 14, 2015, 04:02:03 pm »
If it were mine I would take your original radiator to a radiator shop and get a price it have it repaired.
If the core is clean and leak free and only the neck is leaking at the tank they may be able to fix it while you wait.
A good radiator shop will inspect, pressurize and submerge the radiator in a tank of water and advise you what you have.
You may find it will cost less to repair vs. new and there will be no questions regarding fitment and cooling capacity.
Wish I had followed my own advise before I replaced mine. :)
« Reply #10 on: October 14, 2015, 04:47:45 pm »
it could be leaking from a bad or loose hose clamp or are you sure its rad?
Offline BBM3
« Reply #11 on: October 14, 2015, 05:33:10 pm »
OUCH! (I just slapped myself on the forehead).
Irish is correct check the obvious / easy stuff first.
Also you can borrow a pressure test kit from the chain auto parts stores.
Offline p7387
« Reply #12 on: October 15, 2015, 12:30:12 am »
no its clearly leaking from the joint where the heater hose attaches
i already tried a quick fix with jb weld but no luck
it looks original, its brass
« Reply #13 on: October 15, 2015, 12:55:33 am »
Jb should of done it. It's either it was applied right or it missed the hole
Offline p7387
« Reply #14 on: October 15, 2015, 11:36:40 am »
what about the two size options?
28-1/4 IN X 17 IN core
28-1/4" x 19-3/16" x 1-1/4"
thanks
« Last Edit: October 15, 2015, 11:49:21 am by p7387 »
