Author Topic: Window handle removal..  (Read 7635 times)
Offline philo_beddoe
  • 77 C-10
« on: October 20, 2015, 08:57:27 am »
Whats the easiest fastest way to remove this thing without specialty tools?
Offline timthescarrd
Re: Window handle removal..
« Reply #1 on: October 20, 2015, 09:14:22 am »
I use a 90 degree pick like this to pull the clip off
you can try pulling hard on the handle, it'll sometimes bend the clip out of the way, but if the plastic is brittle it could break
  • 77 C-10
« Reply #2 on: October 20, 2015, 09:16:41 am »
Thanks, I am going to try this guys method first. Just found it, thought maybe there might be another way. I'll post results.
https://www.youtube.com/watch?v=psYYqQhWY2o
Offline blazing816
« Reply #3 on: October 20, 2015, 11:49:46 am »
I use a microfiber clothes.....works better then anything I have tried. Basically find where the ends of the horseshoe clip is and take a microfiber cloth and put it behind the crank and pull it back and forth until the ends catch on the cloth and pop right off.
https://www.youtube.com/watch?v=MIGVyGDuRdI
« Reply #4 on: October 21, 2015, 07:52:00 am »
this is what i do also. the way i do it is find which way its pointing put the rag over the points and pull one end of the rag. the rag will catch the clip end so it wont go flying off and you have to find it
  • 77 C-10
« Reply #5 on: October 22, 2015, 07:56:58 pm »
I will definitly try the rag method first.  Friday i have tons of new parts to install.  New dash pad came in today.  Very exiting, other than the nervous sick feeling in my stomach for dropping $1200 in parts. But this completes the truck.  Amen!
Offline Dr_Snooz
« Reply #6 on: October 22, 2015, 10:53:15 pm »
I've always used a slotted screwdriver. I put the screwdriver up against one end of the clip, give it a smack and push the clip off the spindle. Don't gouge up the door panel though.
  • 77 C-10
« Reply #7 on: November 01, 2015, 03:22:26 pm »
I used a paper clip. Worked great!
« Reply #8 on: November 01, 2015, 06:13:28 pm »
Paint can opener works good
