Author Topic: Can you paint exhaust manifolds?  (Read 8318 times)
Offline philo_beddoe
  • 77 C-10
« on: November 12, 2015, 09:02:19 am »
I am about to install two new ex manifolds. Is there a high temp gray or steel color paint that we can apply to prevent rust and corrosion?
Offline SkinnyG
  • Reducing resale value since 8-track days
Re: Can you paint exhaust manifolds?
« Reply #1 on: November 12, 2015, 09:54:02 am »
There is "header" paint.  Some use "BBQ" paint from the hardware store.
The Crusty Chevy: 1977 Silverado, shortboxed & dropped, potato-potato.
Offline enaberif
« Reply #2 on: November 12, 2015, 10:07:16 am »
I just used plain ole tremclad paint lol.
Offline Eastonfrench
« Reply #3 on: November 12, 2015, 10:38:29 am »
They sell header paint as well at a lot of auto stores. I think it is supposed to stand a little more heat. i used it to paint my brothers exhaust (albeit farther back than the headers) and it seemed to work great.
Heres some:
http://www.autozone.com/paint-and-body/high-heat-paint/thermo-tec-11-oz-aluminum-high-heat-spray-coating/398798_0_0/
Hope that helps!
1980 K10 - 350-Quadrajet-TH350-NP203
  • 77 C-10
« Reply #4 on: November 12, 2015, 10:52:01 am »
Looks good, i'll try that. Say, what is the average temp of a fully hot ex. manifold??
« Reply #5 on: November 12, 2015, 01:11:14 pm »
No more than 1000 degrees i would not imagine
Offline fitz
« Reply #6 on: November 12, 2015, 05:14:54 pm »
Eastwood makes a brush on coating for exhaust manifolds.
I used it on my 79 Jimmy 25 years ago. Wow, time flies.
  • 77 C-10
« Reply #7 on: November 12, 2015, 05:15:00 pm »
Ok, i got gray header paint.  Up to 2000 degrees.
  • 77 C-10
« Reply #8 on: November 12, 2015, 05:18:20 pm »
Yes time dont wait for no one.  I remember when my 79 camaro was at the dealership!
Offline enaberif
« Reply #9 on: November 12, 2015, 05:48:13 pm »
If you don't cure header paint properly it won't stick or work good either fyi.
  • 77 C-10
« Reply #10 on: November 13, 2015, 12:09:22 pm »
How do you cure it??
Offline enaberif
« Reply #11 on: November 13, 2015, 12:27:19 pm »
Read the instructions? :P
  • 77 C-10
« Reply #12 on: November 13, 2015, 10:16:36 pm »
Okay, bake at 250, 400, 600 each 30 min. My oven dont go up to 600.  Now what?
  • 77 C-10
« Reply #13 on: November 13, 2015, 10:19:23 pm »
Goes up to 550, close enough!
  • 77 C-10
« Reply #14 on: November 13, 2015, 10:30:25 pm »
Actually it can be done on the vehicle too by letting engine run and cool three times for x amount of time.  All set.
