Author Topic: Doors from an 85 fit an 80  (Read 5784 times)
Offline chevybones87
« on: November 17, 2015, 10:08:49 am »
Found a  donor truck...will they interchange?
Offline AZ87V10
Re: Doors from an 85 fit an 80
« Reply #1 on: November 17, 2015, 11:04:44 am »
Yes they'll interchange. The main difference will be the door panel styling will be cosmetically different, but you can swap those. I guess the major thing is if you have any power options in either door style? But if you don't care about that then the doors themselves will physically bolt on and interchange. The doors that were different would be 73-77 doors. The inner metal design was different on them due to the shorter door panels and the interior structure was different due to no power options.
« Reply #2 on: November 17, 2015, 02:32:56 pm »
10-4 thanks for your help
« Reply #3 on: November 17, 2015, 06:43:41 pm »
Actually it's 73-76 that had the short door panels
Other minor differences are door seals, glass and weather stripping although they will interchange within the door frame.
Offline AZ87V10
« Reply #4 on: November 18, 2015, 11:22:01 am »
Well, I knew that I was close! Lol! Thanks for the correction. I actually knew that too and still typed it wrong! Oh well! Hopefully this helps him out and any others who are looking and might want to know.
