Author Topic: non A/C heater box  (Read 3246 times)
Offline TNBandit
non A/C heater box
« on: November 20, 2015, 07:05:03 am »
OK new guy here with my first question. My 74 C10 originally had air conditioning. But when I bought it the prior owner had removed everything. Ducts, inside & outside heater boxes, heater controls, etc. and blocked off the firewall with sheet metal riveted over the holes. I would like to put a heater in but don't care about having A/C. What mods do I need to do to install non-A/C stuff ? Anyone have a picture of the firewall from under the hood with the heater box removed so I can see what's different ? I do have access to a non-A/C parts truck. Thanks.
Offline Jason S
Re: non A/C heater box
« Reply #1 on: November 20, 2015, 08:55:41 am »
Welcome from Kansas!
The holes in the firewall were different between the A/C and heater only trucks.
See the link below for photos of firewall going from A/C to non-A/C.  In the photo, the center hole had already been cut for the heater box, the original A/C hole is the rectangular hole.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=21690.msg179454#msg179454
Offline TNBandit
« Reply #2 on: November 20, 2015, 09:28:23 am »
That helps. Thanks
Offline harcorshe
« Reply #3 on: November 26, 2015, 03:49:49 pm »
I just "deleted" my non-working A/C and used "ACdelete" or some such named website to fix up the firewall. Here is a before and after...
« Last Edit: November 26, 2015, 03:51:48 pm by harcorshe »
'78 K20
454
TH400
14 Bolt
205 Transfer Case
