Author Topic: 250 inline 6 only turns over half way!!!  (Read 15479 times)
Offline hotrod24
Re: 250 inline 6 only turns over half way!!!
« Reply #15 on: December 04, 2015, 09:28:38 am »
The truck is a automatic!!!
1978 pontiac grand prix...
Offline werewolfx13
« Reply #16 on: December 05, 2015, 11:27:26 am »
Sounds like flash rust inside the cylinders, but how did you test the starter? Parts store testers dont put a load on the starter drive gear. Turn the motor over by hand and see if it stops that way too. Have you pulled the plugs yet?
Chris
'83 Chevy c10 Silverado SWB
Offline hotrod24
« Reply #17 on: December 05, 2015, 03:58:13 pm »
I tested the starter with jumper cables!!! Yea I am going to turn the motor over by hand on Monday and no I have not pulled the plugs yet!!!
Offline werewolfx13
« Reply #18 on: December 06, 2015, 12:14:34 am »
Did you remove the starter and test it, or was it still mounted? If removed, again, you can't load the drive gear, so the starter may spin fine, but won't turn over an engine. If it was still mounted and cranked the engine over just fine, then you're up against a wiring problem.
Chris
Offline 80Chevy4x4
  • Honey this only costed a couple of dollars!
« Reply #19 on: December 06, 2015, 07:33:03 am »
Ok one time I had a vehicle do that and what happened was the timing chain broke....if you pulled all the plugs and tried to crank it and it did the same thing and it is an automatic and you had the starter checked out.....have you tried to turn the motor over by the harmonic balancer?   try to turn the motor in each direction...and if the motor stops while turning it by hand try to listen to see if you can hear a cluck or some noise and where abouts you hear it at.
Offline hotrod24
« Reply #20 on: December 07, 2015, 04:47:05 pm »
Ok I put some bolts in the harmonic balancer and was tighting them up so I could turn the motor over and when I got the one bolt just tight. The motor turned and it kept turning then stopped so I took my bracker bar and started turning it more. It felt like it was a little stuck!!! Oh and I did not take out the plugs yet...
I also swaped starter housings so I will be putting it on!!!
« Last Edit: December 07, 2015, 04:53:23 pm by hotrod24 »
Offline 80Chevy4x4
« Reply #21 on: December 08, 2015, 04:30:25 pm »
ok take the plugs out...it could possibly be something like fuel or water in a cylinder causing it to lock up....you would be surprised.
Offline hotrod24
« Reply #22 on: December 08, 2015, 06:03:15 pm »
Ok Thanks!!!
Offline 80Chevy4x4
« Reply #23 on: December 08, 2015, 07:23:10 pm »
keep us informed on what you do....take the spark plugs out and then try to crank it...look for anything spewing out of any of the cylinders if it is able to keep cranking over.
Offline hotrod24
« Reply #24 on: December 09, 2015, 04:32:50 pm »
Ok I pulled the plugs and it turned over faster. So I guess it was a little stuck. I put the plugs back in and starter and battery and hit the switch and it turn over!!! Yay!!!!
« Last Edit: December 09, 2015, 04:41:38 pm by hotrod24 »
Offline 80Chevy4x4
« Reply #25 on: December 09, 2015, 08:22:01 pm »
glad you got it running    :)
Offline hotrod24
« Reply #26 on: December 10, 2015, 08:41:36 am »
Thanks for all yalls help!!!
« Reply #27 on: December 10, 2015, 05:29:01 pm »
did you pull the spark plugs?
Offline hotrod24
« Reply #28 on: December 11, 2015, 12:24:50 pm »
Yea I pulled the plugs! But I think I am going to have to do it agian and put some oil in the cylinders. Because it still is not turning over like it was!!!
« Last Edit: December 11, 2015, 03:38:16 pm by hotrod24 »
« Reply #29 on: December 11, 2015, 02:46:25 pm »
lol i never saw the second page
