Author Topic: Breaks  (Read 11648 times)
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: Breaks
« Reply #15 on: December 09, 2015, 05:13:11 pm »
Yup hub definitely needs to be pulled, which means you'll need the 6 prong socket for the wheel bearings nut
 1986 Chevy K30(under repair)
Offline werewolfx13
Re: Breaks
« Reply #16 on: December 12, 2015, 02:12:07 am »
I would almost, almost lay money on that being a 3/4 ton rear end with 11" drums. The 13" drums look a little different IIRC.
Chris
'83 Chevy c10 Silverado SWB
Offline Justin84k10
Re: Breaks
« Reply #17 on: December 13, 2015, 06:41:32 pm »
After I pull the hub I'll measure it then just to make sure I order the right stuff. Looks like it could have been a dually though the way the brake drum hangs out of the tire.
2006 Gmc regular cab short bed 4.8 v8 daily driver
1984 Chevy k10 regular cab long bed plow truck
84 shorbed parts truck
A bunch of parts 80% of a truck. Have to put them together
Offline werewolfx13
Re: Breaks
« Reply #18 on: December 13, 2015, 11:34:08 pm »
Thats the way normal SRW 14 bolt full floating axles are set up.
Chris
Offline Justin84k10
Re: Breaks
« Reply #19 on: December 15, 2015, 07:26:15 pm »
Took it off today, 13 inch drum. Now I just have to order parts. Thanks for all of the help!
