Author Topic: Breaks  (Read 11647 times)
Offline Justin84k10
Breaks
« on: December 01, 2015, 06:37:07 pm »
I am going to replace breaks on my truck, 84 k10 and at some point the rear axle was swaped to an 8 lug 14 bolt rear end. I am unsure of how to identify what Parys to buy because I have no idea what does to the axle. Is thier any way to tell what parts I need (drum, shoes, springs Ect) without knowing the year of the axle? Any help would be appreciated
2006 Gmc regular cab short bed 4.8 v8 daily driver
1984 Chevy k10 regular cab long bed plow truck
84 shorbed parts truck
A bunch of parts 80% of a truck. Have to put them together
Re: Breaks
« Reply #1 on: December 01, 2015, 07:23:32 pm »
So you have 6 lug wheels on the front and 8 lug wheels on the back? Sounds like your best bet is to use a K20 application for parts look up.
P.S. Brakes not Breaks. There not their.
Offline Justin84k10
Re: Breaks
« Reply #2 on: December 02, 2015, 08:05:47 am »
The brake drum looks more like a one ton as if it came off a dually though? And my bad didnt read the post before I put it out
Offline Justin84k10
Re: Breaks
« Reply #3 on: December 02, 2015, 08:06:44 am »
Yes 6 lug on the front and 8 on the back.
Re: Breaks
« Reply #4 on: December 02, 2015, 06:16:41 pm »
Full floater? Post a pic, use a K30 application
Offline Justin84k10
Re: Breaks
« Reply #5 on: December 03, 2015, 07:26:26 pm »
Pretty sure it's a full floater. I'll post a pic tomorrow afternoon when I'm around it!
Offline Justin84k10
Re: Breaks
« Reply #6 on: December 04, 2015, 05:49:04 pm »
Here's a few
Offline werewolfx13
Re: Breaks
« Reply #7 on: December 05, 2015, 12:09:20 am »
Based on what I can see of the drum, thats a 3/4 ton 14 bolt full floater with the smaller 11" drums. The smaller drums being the giveaway that its a 3/4 ton axle, as thats the only appreciable difference.
Chris
'83 Chevy c10 Silverado SWB
Offline Justin84k10
Re: Breaks
« Reply #8 on: December 05, 2015, 11:01:59 am »
Here's a few more. Just wanting to make sure
Offline werewolfx13
Re: Breaks
« Reply #9 on: December 05, 2015, 11:21:31 am »
To be sure, pop the drum off and measure the inside diameter. 11" would be a 3/4 ton, 13" would be either 3/4 or 1 ton.
Chris
Offline Justin84k10
Re: Breaks
« Reply #10 on: December 06, 2015, 11:12:33 am »
How exactly does the drum come off, after I take the tire off it doesn't move and I don't really know much about drum brakes.
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
Re: Breaks
« Reply #11 on: December 06, 2015, 11:52:21 am »
I think the early 14bolts you have to remove hub and wheel bearings. If it was or is a dually axle you have to remove hub to remove drum. Got a pic of drum with wheel removed?
 1986 Chevy K30(under repair)
Offline Justin84k10
Re: Breaks
« Reply #12 on: December 06, 2015, 03:23:57 pm »
I don't have one currently, I'll take one tomorrow evening
Offline werewolfx13
Re: Breaks
« Reply #13 on: December 07, 2015, 12:25:01 am »
Thats correct, removal of the drum is facilitated by removal of one of the axle shafts, then the wheel, and then you might have to back off the adjusters to slide the drum off.
Chris
Offline Justin84k10
Re: Breaks
« Reply #14 on: December 09, 2015, 03:39:16 pm »
Sorry about the late reply, have been organizing my workspace, here's the pictures with the tire off.
