Body, Glass & Paint
Enamel or urethane
Topic: Enamel or urethane (Read 5701 times)
claude
Enamel or urethane
December 13, 2015, 02:00:02 pm »
This is my first time paint project. Completed body work and block sanded my 85 K20. I am ready to spray paint with HVLP. I have narrowed paint to a two part single stage paint (Omni) through PPG (only store within 125 miles). My question is, shall I paint with acrylic enamel or acrylic urethane?
Last Edit: December 13, 2015, 09:23:15 pm by bd
1985 K20, manual T, 373 gears, 208 transfer case
Rebuilt roller 355 engine, Comp XE264XR cam 212/218 @ .050, .487/.495 lift w/1.5 RR, LSA 110, Dart Iron Eagle Heads with 2.02/1.6 SS valves. 325 HP at 4000 RPM. 335 HP @ 4900.
421 ft*lbs torque at 4000RPM
ccdually
Re: Enamel or urethane
December 13, 2015, 03:19:40 pm »
As a painted, I prefer urethane. The new urethanes have a better gloss.
Last Edit: December 13, 2015, 09:23:40 pm by bd
Engineer
December 13, 2015, 07:55:02 pm »
Urethane is supposed to be more durable. Less likely to scratch, and chip.
Urethane is typically chosen for fleets/commercial for its resistance to damage.
Last Edit: December 13, 2015, 09:24:01 pm by bd
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
claude
December 14, 2015, 10:18:14 am »
Thanks Engineer and CCDually. I am going with urethane. PPG paint store doesn't or will not give much advise, even to describe the pro's and con's. It appears 90+ of their business are to established body shops where PPG delivers their products to those shops.
Engineer
December 14, 2015, 04:53:19 pm »
My local PPG store was really helpful. I used to be a DuPont guy but after using PPG one time I'm looking toward PPG for now on.
My local PPG store is 90% body shops as well but didn't mind helping me. I guess cash talks. That, and the store clerk is a cousin to a friend of mine.
jumbowolfe
December 16, 2015, 10:21:35 am »
The only consideration I would warn you about with Omni is that, while it has a reduced cost of normal PPG clear, it will not have the same UV protection. My friend is a paint and body guy and said the cheaper clears will have a very low UV protectant that over time will fade the color.
I've shot OMNI on some guitar bodies before for restoration. Shoots very easy and is great for non-sunny states. If you're located where there is pounding sun, I would not recommend OMNI at all.
Just an FYI.
1978 Chevy 4x4 SWB K10 - Yeller 2 - Currently Owned
1978 Chevy 4x4 SWB K10 - Yeller - Sold in 1989, regretted it every day since.
Body, Glass & Paint
Enamel or urethane
