Author Topic: Distributor not firing  (Read 3603 times)
Offline bigge31566
« on: December 21, 2015, 03:59:34 pm »
I have been trying to start my truck with Chevy 350 with a Accel HEI dist but Im not getting fire to plugs, I checked power to dist at little over 12 ams, but when trying to  crank it drops to between 8 and 9 volts, is this enough to still fire off,
Offline Rattler12
  • Old Geezer
Re: Distributor not firing
« Reply #1 on: December 23, 2015, 09:36:37 am »
If its dropping that low do a battery check and put a load directly on the battery with terminals removed. If the battery tests @ 12.5 V while not under load and drops to 8 under load sounds like a bad battery. Is the starter turning at regular speed?
83 C-10 shorty 454, 5spd, 3:73 posi
Offline Captain Swampy
  • Wisconsin
« Reply #2 on: December 25, 2015, 09:15:33 pm »
Your battery sounds weak, but the ignition should still fire. You might have a bad ignition module or coil. Is the power wire hooked up to the correct terminal on the distributor?
Offline edgarollins
  • Eddy
« Reply #3 on: December 27, 2015, 07:02:18 pm »
In agreement with Rattler, it could be an indication of a bad battery.  Some HEI distributors won't fire on anything less than 10v, or at least that was the case with the original equipment from Chevy.  Have the battery tested at a local auto store.  Most do it for free and you will know for sure.
