Author Topic: 90 Blazer with a Fisher MM2 EZ-V plow.  (Read 6639 times)
Offline fitz
« on: December 21, 2015, 07:21:39 pm »
I bought a plow truck.
I'm passing papers on a new house at the end of January.  It has  a long  driveway so this should do the trick.
It's a 90 Blazer Silverado with a Fisher MM2 EZ-V 8.5' plow.  Its the first Blazer I've seen with a plow this big. It seems to handle it well, we will see how it works out.
  The game plan is to use this truck for a driveway plow for the winter. In the spring I will put the plow set up on my M1028.
Offline LTZ C20
Re: 90 Blazer with a Fisher MM2 EZ-V plow.
« Reply #1 on: December 21, 2015, 10:10:18 pm »
That looks good. That's a big plow!
LTZ Cheyenne C20
Offline fitz
« Reply #2 on: December 21, 2015, 11:36:33 pm »
The plow is big for a 1/2 ton.
I'll have to check the weight of it compared to an old fisher speedcast 7.5' traditional style plow.  The front end doesn't sag as much as I thought it would lifting an 8.5' plow.
  I've seen 2004ish Chevy 2500HD's with plows on them that do nose dives when lifting the plow. This truck doesn't do that..
  I'll just use it as a driveway plow for the winter, not an over the road daily driver. In the spring the plow will go on the M1028.
 The M1028 is rated as a 5/4 ton truck. With 4.56 gears, a Detroit locker in the rear, limited slip Dana 60 front, and 2" Tough Country HD front springs, this truck should handle the plow fine.
Offline LTZ C20
« Reply #3 on: December 22, 2015, 01:56:42 pm »
I'm surprised it holds the weight. Tho remember that the blazer uses front springs and 2004ish 2500s use torsion bars to support the front weight. Tho they work well, they don't supprt the weight at the same point the springs do.
LTZ Cheyenne C20
Offline 1967KaiserM715
  • 1985 GMC K1500 w/ 6.5 TD
« Reply #4 on: December 22, 2015, 04:45:53 pm »
how many leaves on the front? I've seen a couple people put the 4 leaf HD's up front on plow trucks
 1986 Chevy K30(under repair)
Offline fitz
« Reply #5 on: December 22, 2015, 04:59:48 pm »
3 leafs per spring & the factory quad shock set up.
