Author Topic: TH350 issue  (Read 5417 times)
Offline FlatBlack77
TH350 issue
« on: December 24, 2015, 10:33:53 am »
sorry for this being a bit long winded
my 79 has a th350/203 setup. the transmission has a Jasper plate on it so its probably not the original transmission. but it could be 20 years on i really have no idea. the previous owner had the truck for almost 5 years and he never had a problem with it. prior to that it sat for a few years.
ive had it for over a year and half and never had a single problem with the transmission. i never beat on the truck or hold it in gear or anything. it hardly ever sees over 2500rpms. i dont tow or pull anything either and no offroading.
so 2 weeks ago i had planned to do the pan gasket because it leaked slightly. odd timing for this issue to arise. i was on a backroad at about 25mph and i hit a bad bump in the road that i usually avoid but my mind was on other things and it was dark. so i hit the bump pretty hard and just kept driving around 25. about 30 seconds later the transmission downshifts into 2nd which is no big deal i was going slow and very light on the gas but it didnt shift back into 3rd when i sped up a bit. then i came to a red light a minute later so i didnt think too much of it.
i didnt have any trouble for the next 3 days then i came to a stop and it didnt downshift into 1st. it stayed in 2nd. this happened once or twice over the next few days.
so i changed the pan gasket as i had planned to do and the fluid was very red and surprisingly clean. very minimal "dust" or "soot" in the bottom of the pan and no chunks. the magnet had a light coating on it but nothing horrible. the filter was very clean aswell.
during this process i noticed that the vacuum line had popped off the module on the transmission. so i replaced the rubber end and used a hose clamp so it wouldnt come off again. i figured this was the not downshifting into 1st issue.
warmed it up and topped off the fluid and took it for a spin and once it didnt downshift into 1st when i stopped. i shifted it manually and it went right into 1st then shifted normally as i got up to speed. then i stopped again and it didnt shift into 1st so i waited about 10 seconds then it did and shifted normally after that.
so i read around online and came across a few people that said a sticking governor could cause this. so this morning i pulled the governor out and it was sticking very slightly. like just barely sticking. i sprayed it with some brake cleaner and it freed it up and it passes the "gravity test".
im taking a break from it right now before i put it back together but id like some advise or any input whatsoever on the topic. ill take anything i can get ive got my fingers crossed that a slightly gummed up governor is the problem. i really dont want to have this thing rebuilt.
cheers guys!
Re: TH350 issue
« Reply #1 on: December 24, 2015, 10:42:51 am »
Well you will need to put the governor back in and tell us how it is first.
Offline FlatBlack77
Re: TH350 issue
« Reply #2 on: December 24, 2015, 11:41:24 am »
no difference. still doesnt want to drop into 1st when coming to a stop or slowing way down. not every time but at least half the time.
Offline FlatBlack77
Re: TH350 issue
« Reply #3 on: December 24, 2015, 11:53:48 am »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=17358.15
i just read through this thread and realized i didnt actually check if the "valve" is moving. i just checked that the flappers move. so the governor could actually still be the problem
Re: TH350 issue
« Reply #4 on: December 24, 2015, 12:09:07 pm »
It is very easy to pull apart so pop it back out and check again. If it is sticking you can usually repair it fairly easily.
Offline FlatBlack77
Re: TH350 issue
« Reply #5 on: December 24, 2015, 12:15:25 pm »
its sticking badly. im soaking it in solvent right now
Offline FlatBlack77
Re: TH350 issue
« Reply #6 on: December 24, 2015, 12:54:09 pm »
blew it out and freed it up now it shifts perfectly.
i guess i got ahead of myself making this thread and thinking it wasnt going to be a simple easy fix.
thanks for your help and in the other thread too Vile 8)
Re: TH350 issue
« Reply #7 on: December 24, 2015, 01:33:52 pm »
Glad you got it worked out!
Offline rich weyand
Re: TH350 issue
« Reply #8 on: December 24, 2015, 02:01:10 pm »
As with many things, the fix was pretty easy.  The diagnosis is where most people fall short.
Anyway, nice you got it fixed!
