Author Topic: not moving  (Read 5518 times)
Offline achevy1978
not moving
« on: January 03, 2016, 04:14:19 pm »
try to make this short,
took 78  out to put plow on. drove up to old speedcaster and of course i had to go for/rev a few times, then all of sudden nothin..no movement.. th400 nice pink fluid. 203 tc just changed oil. i dont think its tranny cause i can hear the parking pawl trying to catch when go to park,. like tc is in neutral...no linkage is off and it feels like something there when shifting tc...is it possible to get one stuck in neutral??...i can pull this in park...
thanks
Offline hatzie
Re: not moving
« Reply #1 on: January 04, 2016, 09:26:27 am »
I wouldn't pull it in park.
If you set the transfer case in neutral you can probably get away with towing a short distance.
An NP203 truck won't have front axle hub locks unless someone put a part time kit in it.
An unmodified NP203 operates as if it has an open diff inside between the front and rear driveshaft so if something breaks in between the transfer case and any wheel it sends power to the wheel that's no longer attached.  When shifted into Hi-Loc or Lo-Loc, the transfer case differential locks to provide equal power to both driveshafts.
If the front or rear drive-line has a failure the whole truck will stop moving with the transfer case selector in regular Hi or Lo modes.
Will she move if you set the transfer case range shifter in Hi-Loc or Lo-Loc and the transmission in gear?
Offline achevy1978
Re: not moving
« Reply #2 on: January 05, 2016, 06:45:20 pm »
nope...and park is like neutral so it seems the tc is in neut...yes i put a conversion kit in years agoe
linkage all looks good....i did find the adjustment procedure...just to cold for these old hands
thanks
Offline achevy1978
Re: not moving...UPDATE!
« Reply #3 on: January 06, 2016, 07:25:25 pm »
pulled tc and it seems fine.... haven't  pulled trans apart yet but looks like broke output shaft on th400...
Re: not moving
« Reply #4 on: January 10, 2016, 08:19:12 pm »
Out put shaft in the trans mission probably broke off.
Just replaced the trans in my 87 V20 because the output shaft broke. Tends to be the one week link in a TH 400.
Re: not moving
« Reply #5 on: January 10, 2016, 09:45:48 pm »
with the output shaft you can also break the transfer case adapter this will allow t case to separate enough to slie out of the coupler
Offline achevy1978
Re: not moving
« Reply #6 on: January 11, 2016, 05:38:35 pm »
by adapter you mean the cast iron mount or the female spline on the tc ?
thnx
Re: not moving
« Reply #7 on: January 12, 2016, 12:52:56 am »
The plate that connects the transmission to the transfer case. Or like blaze said you can break the output or input shaft or the sleeve
« Last Edit: January 12, 2016, 01:03:55 am by Irish_Alley »
