Author Topic: Braking issue...fixed pics  (Read 49624 times)
Offline gunrac
Re: Braking issue
« Reply #15 on: January 28, 2016, 09:26:50 am »
AutoZone reman calipers
1/2 of what I paid at NAPA.........I wasn't as thrifty then.....lol
Never Apologize..........as it shows signs of weakness
Offline frotosride
    • WFO CONCEPTS
Re: Braking issue
« Reply #16 on: January 28, 2016, 04:56:10 pm »
Gotma pair from the big O.. So the plan is this weekend but I'm painting them first. They were 54 but 10 core for each so total of $34.
Offline JasonD45
Re: Braking issue
« Reply #17 on: January 30, 2016, 04:42:48 pm »
I have no where near as much knowledgable input as the rest of these good men, but my '87 v20 has an 8" lift and the ride is miserable! My 9 month old loves it cause she just bounces. I use it primarily as a beach truck, and I've hopped people out of their seats at 10-15 mph. I can't complain though, I got it for $500
Offline frotosride
    • WFO CONCEPTS
Re: Braking issue
« Reply #18 on: February 08, 2016, 09:15:09 pm »
No complaints here either,  8 got mine for free and I personally made it ride rougher.
Offline frotosride
    • WFO CONCEPTS
Re: Braking issue
« Reply #19 on: February 08, 2016, 09:19:10 pm »
 Got the new/reman calipers ready to go on. I'm also going to try adding a smidge of toe to help with the steering/ slight wondering. I have some alimnium plates and aluminum angle iron t9 make my toe plates. Just gotta weld them together.
Offline LTZ C20
Re: Braking issue
« Reply #20 on: February 08, 2016, 10:29:14 pm »
Why are they florescent baby blue?
LTZ Cheyenne C20
Offline enaberif
Re: Braking issue
« Reply #21 on: February 08, 2016, 10:49:32 pm »
blue fetish?
Offline LTZ C20
Re: Braking issue
« Reply #22 on: February 08, 2016, 11:07:19 pm »
blue fetish?
Thats what I was wondering.... I don't think it matches the blue his truck is.
LTZ Cheyenne C20
Re: Braking issue
« Reply #23 on: February 09, 2016, 05:06:21 pm »
Smurfs special.
What do you mean you are adding toe to help with wandering?
Offline frotosride
    • WFO CONCEPTS
Re: Braking issue
« Reply #24 on: February 09, 2016, 05:54:07 pm »
I don't know why they look like that in the pic. It's acutely VHT HEADER paint.
blue fetish?
Not really that worried about matching perfectly.  But fetish...well I may like blue a little.
Smurfs special.
Ha😛.  I'm at zero toe. I plan on toeing in slightly. Obviously I'm gonna recheck my toe before adjusting anything.
« Last Edit: February 09, 2016, 05:57:33 pm by frotosride »
Offline LTZ C20
Re: Braking issue
« Reply #25 on: February 09, 2016, 09:24:18 pm »
Ok, but what color VHT paint did you use? Let me guess, blue? Lol
LTZ Cheyenne C20
Offline frotosride
    • WFO CONCEPTS
Re: Braking issue
« Reply #26 on: February 10, 2016, 01:16:36 pm »
Nope ..BBBBLLLLUUUE I think that's they way it's spelt on the can
Offline LTZ C20
Re: Braking issue
« Reply #27 on: February 10, 2016, 10:38:38 pm »
LOL.
LTZ Cheyenne C20
Offline frotosride
    • WFO CONCEPTS
Re: Braking issue
« Reply #28 on: March 21, 2016, 08:40:47 pm »
Ok so after having these new calipers for over a month I finally got around to installing them. Unfortunately the only change is the blue color of my calipers. Two things to note..
1) I have a bump steer issue as well and guess which direction of travel I go when I'm not correcting it immediately. .. it goes right just like when I brake at any rate over 1/4 pedal travel.im sure I have some geometry that's off.. not that it was ever that good in the first place.
2)I cannot get my tires to lock up for the life of me. Yesterday after I finishes a ridiculous amount of bleeding I went for a test drive to find out it still pulls to the right. I also double footed the brake pedal and used the steering wheen for leverage, couldn't lock up my brakes from  45mph. What gives! Apparently the weight of my stuck to inertia!
Offline blazer74
Re: Braking issue
« Reply #29 on: March 21, 2016, 11:21:25 pm »
Did you resurface the rotors and install new pads at the same time?
Brake hose condition?
New pads will not seat correctly if the glaze is not removed from the rotors and will pull if uneven wear is not removed by surfacing also.
Contaminated brake pads will also grab unevenly.
Rear brakes adjusted properly?
Bleeding procedures furthest from the MC first, then next furthest with a helper or a pressure bleeder.
Bleeding all four brakes for the pro portioning valve to operate properly.
Master cylinder condition also.
