Author Topic: Braking issue...fixed pics  (Read 49634 times)
Offline frotosride
    • WFO CONCEPTS
« on: January 23, 2016, 09:16:40 pm »
I've had the same problem for a while now and I just. Checked all pads and hoses 3 days ago so I guess I'm gonna start with re bleeding the left driver's side and go from there. I've never gotten the dummy brake light but it could be broke or disconnected. The PV is the same one since '87 so we will see. I will post any progress as well if you wish since it is your thread Usareke
« Last Edit: July 29, 2020, 09:55:02 pm by frotosride »
Offline frotosride
    • WFO CONCEPTS
Re: Braking issue
« Reply #1 on: January 23, 2016, 09:57:51 pm »
Here's a little idea of how bad it is. This is at roughly 30mph.
Offline Usareke
Re: Re: Braking issue
« Reply #2 on: January 23, 2016, 09:59:50 pm »
Yeah man that's about how bad mine is, I have to way correct it to the left to stay on the road.. Its sad lol
Sent from my SAMSUNG-SGH-I317 using Tapatalk
~ Zach
Offline frotosride
    • WFO CONCEPTS
« Reply #3 on: January 23, 2016, 10:00:10 pm »
Did a little skid testing too. This view is from front looking back to where I started braking.
And vice versa.
Offline Usareke
« Reply #4 on: January 23, 2016, 10:01:30 pm »
And vice versa.
Ouch that's a pretty big difference
~ Zach
Offline roundhouse
Re: Braking issue
« Reply #5 on: January 24, 2016, 04:07:57 am »
Have you replaced  the flex hoses on the front ?
They clog up inside
Offline frotosride
    • WFO CONCEPTS
Re: Braking issue
« Reply #6 on: January 24, 2016, 08:16:08 am »
I did both hoses in 2013 when I put the lift on. They were part of the i8t
Offline enaberif
Re: Braking issue
« Reply #7 on: January 24, 2016, 11:41:46 am »
These trucks either stop well or don't stop at all. When they decide to not stop at all its a royal pain in the ass to figure out why and can get expensive fast!
I've replaced every single part of my trucks braking system and it still bloody sucks. I think one of the biggest issues is simply bleeding and doing the 2 person job I don't think cuts it. Gravity bleeding doesn't work well.
Pulling usually ends up being the opposite side of the actual pull in this case if if swings left its the right side which means you probably have caliper issues. These 40 year old trucks people never think of rebuilding or replacing calipers... so check those.
Offline jg1977c20
Re: Braking issue
« Reply #8 on: January 25, 2016, 04:03:32 pm »
the rear drum brakes on  just about any vehicle require a manual adjustment from time to time - and oddly enough it seems the drivers side rear is always out a little more than the opposite side ????   if you took your vehicle to a  garage for oil changes the brake adjustment would always be done then .
1977 c20 cheyenne camper special 8200gvw
Re: Braking issue
« Reply #9 on: January 25, 2016, 07:47:07 pm »
Make sure the calipers are moving freely. If so replace the left side hose.
Offline blazer74
Re: Braking issue
« Reply #10 on: January 25, 2016, 08:19:30 pm »
Replace them both
Offline frotosride
    • WFO CONCEPTS
Re: Braking issue
« Reply #11 on: January 26, 2016, 10:06:32 am »
May have found part if not all of the issue. Both pin-bolts on the driver's side have a slight bend to them. This may be causing the initial catch and once I apply enough pressure everything seems better. Going to look for new bolts hopefully this afternoon. Dorman makes a pin-bolt and guide sleeve kit for $15. Either way these need to be replaced so I'm not replacing needless parts if it does end up being the caliper
« Last Edit: January 26, 2016, 10:21:24 am by frotosride »
Re: Braking issue
« Reply #12 on: January 27, 2016, 07:06:58 pm »
You can buy the whole caliper for under $15
Offline frotosride
    • WFO CONCEPTS
Re: Braking issue
« Reply #13 on: January 27, 2016, 07:43:09 pm »
Quality? And where please. Either Way they never come with hardware so new ones are definitely needed
Re: Braking issue
« Reply #14 on: January 28, 2016, 08:57:36 am »
AutoZone reman calipers
