Author Topic: 1978 Gmc High Sierra C2500 - Camper Special  (Read 5999 times)
Offline sjay
« on: February 04, 2016, 10:22:49 am »
I thought I'd share my truck with you guys. Just picked it up
78 Gmc C25 (Camper special is what the previous owner told me). 350 Small Block rebuilt , Th400 (which is currently leaking all over my driveway), long bed, 8 bolt axles, dual gas tanks. Im going not looking to do a full resto just get it running as a hauler.
So far the problems I need to tackle:
-Figure out why the heck the tranny fluid I put in ends up on the floor. Fix/replace turbo 400.
-redo Front passenger tire - the bead is gone and the tire goes flat
-Need to put back the interior as I received it in boxes. (no screws to go with anything..)
-Figure out why only one gas tank works
-get the fuel gauge to work
-Clean up the paint.
Let the fun begin!!
« Last Edit: February 10, 2016, 10:54:49 pm by sjay »
Offline gunrac
Re: 1978 Gmc High Sierra C2500 - Camper Special
« Reply #1 on: February 04, 2016, 11:38:13 am »
trans leak could just be an o-ring on the modulator or dip stick tube, or possibly a crack on either or. I remember cracking a tube where it meets the tranny, on a engine replacement.
Never Apologize..........as it shows signs of weakness
Offline sjay
« Reply #2 on: February 06, 2016, 08:26:23 am »
I hope its something simple. It's finally the weekend, ill be spending a couple hours underneath the truck. Ill report back with my findings!
I hope it isnt too much of a job/leak, if im going to have it towed to a shop to be repaired i may as well get a rebuilt turbo 400 (there about $200-250)
Offline FlatBlack77
« Reply #3 on: February 07, 2016, 09:08:55 am »
nice start man welcome!
it could be the pan gasket. the fluid will be pretty much all over the place if its a bad pan leak.
other problems could be the kickdown cable seal, cooler lines, govenor cover seal, and probably more
Offline SquareBodyBoy76
  • 17 y/o building 2 trucks
« Reply #4 on: March 01, 2016, 08:18:32 am »
You'll most likely have to replace the tank switch-over valve to get your second tank to work. It may also fix your fuel gauge because I replaced the switch-over valve on my '74 and my fuel gauge is working again.
If you wanna know what I'm made of, just look at my truck.
