Author Topic: Identify my diff  (Read 11908 times)
Offline grey83c20
Identify my diff
« on: February 06, 2016, 01:33:27 pm »
I have a very high level knowledge of differentials. Can anyone school me on how to figure out my gear ratio and if its an open or limited slip carrier?
Sent from my Nexus 6 using Tapatalk
Offline grey83c20
Re: Identify my diff
« Reply #1 on: February 06, 2016, 02:04:52 pm »
I have a 1983 c20. The rear end is a 9.5 inch 14 bolt.
« Reply #2 on: February 06, 2016, 02:32:38 pm »
at the arrow flat part of the ring gear, rotate it until you see the numbers.  A 41 9 would mean 4.56 for example
« Reply #3 on: February 06, 2016, 02:47:03 pm »
You mean don't?
Open differential
If you can't locate the stamp the formula is simple. Driven over drive. # of teeth on the driven gear divided by # of teeth on the drive gear to 1
Offline grey83c20
« Reply #4 on: February 06, 2016, 03:18:00 pm »
Not even a gov lok... Well that makes me sad. When I bought the truck I knew even less about the rear ends in these trucks. Thought I had a ff 10.5 14 bolt and limited slip. Now I have neither :-( lol thank you for the info though
Offline Captain Swampy
  • Wisconsin
« Reply #5 on: February 07, 2016, 11:39:05 am »
It is  full floating if it's a 14 bolt. That means the axle shaft doesn't carry weight, it only transmits torque.
Offline enaberif
« Reply #6 on: February 07, 2016, 11:46:29 am »
If you knew diffs then you'd know to have a 14 bolt FF rear axle you would have a hub with 8 bolts to pull out the axles from the rim side.
Offline grey83c20
« Reply #7 on: February 07, 2016, 08:30:44 pm »
Nope don't know much about them at all. That's why I'm here asking the questions.
http://www.gmsquarebody.com/forum/showthread.php?t=748
Hate to reference a different forum but in the name of correct information here is helpful info about the different 14 bolts gm made that I found after posting here. I have a semi float 14 bolt without hubs to remove the axels. 9.5 inch ring gear. 8 lug.
The full float 14 bolts had the hubs and 10.5 inch ring gears making them much stronger. Anyhoo case closed. I didn't have what I though I had. Thanks.
« Reply #8 on: February 10, 2016, 11:43:12 am »
they were referencing your original post it was a simple typo. but clad you learned, i wasnt sure by the pictures and 1" isnt that much but something didnt look right on about it being a ff. all the times i took mine apart something didnt click about it being a ff
Offline Rattler12
  • Old Geezer
« Reply #9 on: February 10, 2016, 03:03:11 pm »
You may be disappointed that its an open diff........but don't be disappointed it's not a gov lock......I got one and am just waiting......
83 C-10 shorty 454, 5spd, 3:73 posi
