Author Topic: Gear indicator  (Read 10458 times)
Offline Mikeymike383
Gear indicator
« on: February 07, 2016, 09:32:52 pm »
How do u hook up the stock gear indicator? It's on a 78 Chevy 2wd blazer 50,000 org miles missing the gear indicator. But I have a few so I want 2 install
383 stroke
Offline Eastonfrench
Re: Gear indicator
« Reply #1 on: February 08, 2016, 10:18:02 am »
It should be a steel cable. On one end is the orange plastic arrow and a spring. The other end has a metal clip. So it looks something like this
WMWM-=^=----------[]
spring   indic.   cable   clip
The spring end has a small hole it hooks in. The cable goes to the right (if you're facing the windshield) goes around a small round hook and comes back to the left where the plate hooks in a L-shaped notch on the bottom of the steering column. You loosen the screw in the clip and slide it around the notch until the indicator arrow is pointing to the correct gear. As you shift gears the steering column rotates, pulling on the cable, and sliding the indicator. It takes some trial and error to get it set perfect.
1980 K10 - 350-Quadrajet-TH350-NP203
Re: Gear indicator
« Reply #2 on: February 08, 2016, 10:22:55 am »
Here, I drew on a picture i found online. The red line shows where the cable is supposed to loop around.
The square with the hole is the clip that hooks in the slot on the steering column. Good Luck.
Re: Gear indicator
« Reply #3 on: February 08, 2016, 08:57:38 pm »
So i think in missing the cable tht hooks up 2 the gear shifter. Where can I get the cable 4
383 stroke
Offline AZ87V10
Re: Gear indicator
« Reply #4 on: February 08, 2016, 09:10:42 pm »
As far as I know, you can't get just the cable as no one reproduces just that. You're going to need to either check the junkyard or order a reproduction from any number of aftermarket suppliers. The entire assembly is being reproduced as a brand new part. I've gone that route before and had great results.
Re: Gear indicator
« Reply #5 on: February 09, 2016, 07:05:59 am »
If you don't want to do that, you could very easily rig something up with a small piece of speaker wire, or something similar, but you will probably fight adjusting it without the designed clip. Here is a link to a replacement my friend:
http://www.ebay.com/itm/73-87-91-K5-BLAZER-C10-GMC-CHEVY-TRUCK-SHIFT-INDICATOR-SHIFTER-SUBURBAN-JIMMY-/322000219053?hash=item4af8b56bad:g:4ysAAOSw--1WtR3K&vxp=mtr
Re: Gear indicator
« Reply #6 on: February 10, 2016, 08:11:01 pm »
So I have all that just missing the lil clip so where do I hook the clip 4
383 stroke
Offline SkinnyG
  • Reducing resale value since 8-track days
Re: Gear indicator
« Reply #7 on: February 10, 2016, 09:50:40 pm »
I crimped an electrical eyelet on the broken end of the cable where the clip used to go.
The Crusty Chevy: 1977 Silverado, shortboxed & dropped, potato-potato.
Re: Gear indicator
« Reply #8 on: February 11, 2016, 07:50:20 am »
the clip just slides over the steering column at the base of the gear shifter part
