Author Topic: Which seatbelt for newer seat? Does it matter?  (Read 12239 times)
Offline 73FrankenTruck
« on: February 10, 2016, 01:01:28 am »
I have a 73 GMC 3/4ton. Previous owner installed a bench seat (60/40 split, electric, has orange button on receiver) from a later model truck. I need new seat belts. I had planned on using receivers that are already there, just replace shoulder belt.
Do I order belts for a 73, or do I need to order belts to match vintage of the seat?
-C
Offline gunrac
Re: Which seatbelt for newer seat? Does it matter?
« Reply #1 on: February 10, 2016, 04:40:07 am »
Something to keep an eye on......I had the opposite issue. I came across a very nice bench at a local yard. No clue what yr. it came from. Stored it 4 several yrs. I put it in my 85' last yr. It was quite a bit taller (thicker) seat cushion then the original bench. I needed to replace the buckle side for extra length. Even w/the seat all the way back, I could barely hook up.
Never Apologize..........as it shows signs of weakness
Offline enaberif
« Reply #2 on: February 10, 2016, 06:59:12 am »
-C
Considering the buckles are unknown to the truck you'd best just buy new 2 or 3 point seatbelts depending on what was in the truck.
Offline brewster
« Reply #3 on: May 04, 2016, 06:56:11 pm »
Well to my knowledge 3 point belts weren't even offered in a 1973, so most likely they're aftermarket, and i just learned all about this because I am putting 3 point belts in my 1975, so first you have to determine what kind of seat you have 73-80 seats were different than 80-87 seats the 80-87 seat swoop in near the bottom seat belt mount, the 73-80 just go straight back and most aftermarket belts will not fit the seats that go straight back
Sent from my LGUS991 using Tapatalk
« Reply #4 on: May 05, 2016, 04:33:59 pm »
Your mailbox is full Brewster
« Reply #5 on: May 05, 2016, 06:49:29 pm »
