Author Topic: Engine stops running while on the road then starts running again  (Read 9944 times)
Offline Stewart G Griffin
What would cause the engine to stop running while driving for about 5-10 seconds then start running again?   This happened at about 50mph 3 separate times .
Offline Chisholmcody
Re: Engine stops running while on the road then starts running again
« Reply #1 on: February 18, 2016, 09:52:03 am »
My first guess would be a fuel issue
« Reply #2 on: February 18, 2016, 10:53:16 am »
That sounds like an interruption in ignition.  What vehicle is it Stewart?
Offline timthescarrd
« Reply #3 on: February 18, 2016, 11:30:45 am »
I was having this problem when I had a bad 12V connection to my HEI distributor, there was a break in the source line and it would cut in and out
Offline Burkhalter
« Reply #4 on: February 18, 2016, 05:15:19 pm »
Another possibility. About 3 years ago one of the wires that went to the little pickup module under the rotor broke from being bent repetitively for almost 25 years. Then it just completely fell off and didn't run period.
'85 Chevy K10 361ci sm465
« Reply #5 on: February 18, 2016, 05:37:08 pm »
The truck.  It just started doing this today.
« Reply #6 on: February 18, 2016, 08:47:07 pm »
Ok it was something simple----the positive cable from the battery was a little loose.  i had to repeatedly disconnect/connect the negative cable during the recent engine swap never paying much attention to the positive cable.
The clue was, while leaving work it was dark.  So i started it up and tried to get it to come off high-idle which it did, but then all of a sudden it conked out.  No lights, no click, no nothing.    So i figured if i had bright lights a second ago and now no lights at all, then it must be battery/power related and not necessarily ignition which is what i was originally leaning towards.
Thanks everyone.
Everythings got to be CLEAN and TIGHT.
« Reply #7 on: February 18, 2016, 09:01:03 pm »
This ^^^^^   ;)
Offline philo_beddoe
  • 77 C-10
« Reply #8 on: February 18, 2016, 09:26:04 pm »
Those are the fun fixes, wish my "bad vibration" was that easy.
Offline AZ87V10
« Reply #9 on: February 18, 2016, 10:05:42 pm »
Same here! I wish my occasional stumble/stall issue was that simple! I'm tired of throwing parts at it with effect on performance!
Offline LTZ C20
« Reply #10 on: February 18, 2016, 10:31:38 pm »
This ^^^^^   ;)
One the mechanics at work told me once, clean and tight is good, but if it's dry, you got lube it. "If you love it, lube it" were his exact words.
LTZ Cheyenne C20
Offline AZ87V10
« Reply #11 on: February 18, 2016, 10:38:37 pm »
This ^^^^^   ;)
That's really great advice! Thanks for sharing!
Offline LTZ C20
« Reply #12 on: February 19, 2016, 01:05:33 am »
This ^^^^^   ;)
LOL, he's quite the interesting fellow to say the least.
LTZ Cheyenne C20
  • 77 C-10
« Reply #13 on: February 19, 2016, 10:38:20 am »
Totally agree on the lubing it. Some point ago i posted that if i could drive my truck in a swimming pool full of high tech anti corrosion all purpose oil,,,i would!!! Lol
Offline LTZ C20
« Reply #14 on: February 19, 2016, 10:15:12 pm »
That's not driving, that's called floating lol. Well, in a sqaurebody, it's actually SINKING. Hahaha.
LTZ Cheyenne C20
