Engine/Drivetrain
Rear Drivelines, Drive Axles and Gearing
Differential Gasket or RTV sealant ?????
Topic: Differential Gasket or RTV sealant ????? (Read 10964 times)
Pike1915
Trying to kept my sanity
February 22, 2016, 09:36:51 pm »
What are people's thoughts about gaskets vs. RTV for the rear Differential???
LTZ C20
Re: Differential Gasket or RTV sealant ?????
February 22, 2016, 09:42:38 pm »
A quality gasket is just as good as RTV and vice versa. Some vehicles use gaskets, some use RTV from the factory. For one of these trucks, either/or doesn't matter, which ever you want/prefer. I wouldn't hesitate to use either one or the other.
LTZ Cheyenne C20
February 23, 2016, 02:45:02 am »
I usually keep a can of rtv in my truck and one in the shop. And it's all I have ever used on the differential cover
1967KaiserM715
1985 GMC K1500 w/ 6.5 TD
February 23, 2016, 06:51:58 am »
They make a silicone reusable gasket for most axles now, I would use one of those, less messy then rtv and less prone to tears and leaks over regular gaskets
Sent from my LGL34C using Tapatalk
Current Vehicles:1985 GMC K10(Daily) 1991 GMC K2500(Daily) 1975 Beetle(not running) 1985 Mercedes 300D(not running) 1952 M35 1967 M715(not running)
1986 Chevy K30(under repair)
February 23, 2016, 08:48:35 am »
http://www.permatex.com/products-2/product-categories/gasketing/gasket-makers/permatex-gear-oil-rtv-gasket-maker-detail
Rocketbear
Churning n burnin
February 27, 2016, 09:49:53 am »
Used blue rtv on my 14 bolt best seal I've ever done. Lay a bead barley put cover on w bolts n wait over night. Next day tighten down n you'll never look back
February 27, 2016, 03:11:02 pm »
i know with the
Right Stuff
i clean up the cover with a scraper and brake clean, put a bead around the cover and let it sit for 5 or so min or so while i clean the differential face. then put it on and tighten the bolts then add fluid and run it. most times its for the mud truck and then we go out and play with no leakage.
Engine/Drivetrain
