Author Topic: Fuel Pump Push Rod Stuck  (Read 39327 times)
Offline dopeeye
« on: February 28, 2016, 01:42:00 pm »
1975 Chevy C10 with a 350.
Replacing the mechanical fuel pump i mush have messed up the push rod, it is currently jammed in the block with no rotation or any sort of movement. Pump and mounting plate are off, i can barely get a pair of channel locks on there but it wont budge.
Unless someone has a brilliant idea of removing the rod that does not involve welding anything on there i am inclined to switch to a electric fuel pump. Is there a good write-up on how to go about that ?
thanks
Offline LTZ C20
Re: Fuel Pump Push Rod Stuck
« Reply #1 on: February 28, 2016, 02:40:10 pm »
Ok, so you were attempting to replace the fuel pump, you tried to install the rod into the block, now it's stuck in there and won't budge? So your thinking you pushed it to far or inserted it wrong?
It will only go far enough in to the block until it stops at the drive lobe on the camshaft.
If it's in the block and won't move and you can't pull it down, unplug the B+ power wire (the thick red wire) on the distributor, then just bump the starter using the ignition. Like you are trying to start it but so it only turns over a little at a time. The cam drive lobe will rotate and hopefully pop it free.
Do this first and then report back with your findings.
LTZ Cheyenne C20
Offline bd
« Reply #2 on: February 28, 2016, 03:40:03 pm »
Did you remove anything else from the motor to gain a little better access?  One of the bolt holes on the front of the block is drilled through into the pushrod bore.  The hole is there so a "long" bolt can be inserted to retain the pushrod during pump replacement.  The bolt that normally threads into that hole is shorter than the adjacent bolts, yet often is used to retain various mounting brackets.  If you inadvertently swapped the "short bolt" with a longer one, it will lock the pushrod solid.
Another, albeit slim, possibility is that the pushrod was bent while tightening the fuel pump bolts.  If that is the case, defeating the ignition and then bumping the starter with the fuel pump and plate removed as suggested by LTZ may pop it loose.  You can check its linearity by rolling it on a flat surface once you get it out.
Offline dopeeye
« Reply #3 on: February 28, 2016, 04:09:55 pm »
Already tried bumping the starter, I turned it over several times but the rod wont budge. I never messed with the screw that is in some cases used to hold the rod in place during install. My guess is that I bent or scratched the rod during install and when i moved it into the block it got jammed.
I tried several tricks to get the rod to move (i.e tapping a 12mm socket over it to rotate it but with no success) the rod is in the block goodandtight.
I am heading down the path of electrical pump, can anyone suggest a decent conversion kit or do i just get a universal pump and be done with it ?
Thanks for the suggestions so far
Offline FlatBlack77
« Reply #4 on: February 28, 2016, 04:46:21 pm »
can you push it in any farther? i dont mean hammer it in im just wondering if it loosens up once it is pushed in a little bit. you may be able to push it in then bump the starter again to budge it free
« Reply #5 on: February 28, 2016, 05:13:07 pm »
back to BD's point, did you remove the bolt to ensure it is not binding against the rod?
Offline LTZ C20
« Reply #6 on: February 28, 2016, 06:09:04 pm »
Double check and make absolutely sure that the bolt is not holding the rod tight. Then if you only bumped if over a few times and it didn't budge, maybe holding the starter engaged long enough for it to make 4, 5 or 6 full rotations may be better. The lobe may have been on the beginning of the low side and a few bumps only brought it to the beginning of the high side and so it needs to travel over the high side of the lobe a few times to break it free.
LTZ Cheyenne C20
Offline dopeeye
« Reply #7 on: February 28, 2016, 09:24:09 pm »
The bolt was not touched since i got the truck 3 years ago, it was running fine until a few weeks ago when it started stalling. I rebuilt the carburetor, re-ran all the vac lines. My latest step was to replace the fuel filter and the fuel pump. While I have not actually checked the bolt, there is no way the bolt would have been replaced since it was running fine before. I tried tapping it and cranking the engine multiple turns, no movement.
thanks
Offline frotosride
    • WFO CONCEPTS
« Reply #8 on: February 29, 2016, 02:16:48 pm »
I have used a shop vac in older sludged up engines to suck the rod out... It's worth a shot.
Offline dopeeye
« Reply #9 on: February 29, 2016, 02:21:24 pm »
Thanks for all the suggestions. I have decided for now to go with an electrical pump, so i can at least use the truck till i find someone with a mig welder and a steady had that can weld something onto that rod.
Any suggestions on which pump or are they pretty much universal ?
Offline frotosride
    • WFO CONCEPTS
« Reply #10 on: February 29, 2016, 02:35:37 pm »
If your in SE Georgia then I got a MIG, tig and a mildly steady hand.
Offline blazer74
« Reply #11 on: February 29, 2016, 03:03:08 pm »
That rod rides on the camshaft and pushes the pump lever, how could it be stuck inside when you have  rotated the engine?
That would push it out mechanically.
There's no give there.
Something's sounds quite wrong there, seems to me. I'd be concerned with internal damage
That rod has to come down to get the camshaft out or it will interfere with the cam lobes.
Every Time   I've changed a fuel pump holding the rod up is the issue, always wants to slide down.
Offline dopeeye
« Reply #12 on: February 29, 2016, 03:09:01 pm »
Thanks for the offer but I am in Seattle, unless its all down hill from here :)
My guess is that the rod in in its lowest (pump lever compressed) position, and unless i hammer on it it wont go back into the bore, so there is nothing for the cam lobe to push on.
Offline LTZ C20
« Reply #13 on: February 29, 2016, 03:40:52 pm »
I think at this point, pictures are worth a thousand words.
LTZ Cheyenne C20
Offline blazer74
« Reply #14 on: February 29, 2016, 04:06:21 pm »
So it's not all the way up to where You can't get a hold on it with something and pull twist out?
You can replace it if you damage it.
